Home » Eclipse Projects » Eclipse Platform » Exportwizard enablement for specific project
Exportwizard enablement for specific project [message #331671] Tue, 16 September 2008 04:35 Go to next message
How can I create an exportWizard that can only export my custom Project?
Best would be if, when user selects my CustomExportWizard in the Eclipse
export selection dialog, that an error message is shown saying: "You
need to select a project of type CUSTOM to export with this wizard". Is
this currently possible?
An alternative would be that the exportwizard does not even show up for
certain selections. I tried using the <selection> tag of the extension
point but that was too limited and did not do the trick. Are there any
other ways of achieving this behavior?
/Ola
Re: Exportwizard enablement for specific project [message #331685 is a reply to message #331671] Tue, 16 September 2008 07:51 Go to previous message
You would probably have to use a subclass of the standard "pick a
project" page. If it gets pre-populated correctly you are good to go,
if not you put up an validation error message and disable the Next button.
Check out org.eclipse.ui.dialogs.WizardExportResourcesPage
PW
Paul Webster
Previous Topic:Multiple eclipse version support.
Next Topic:Contribute to Resource Navigator New Submenu
Current Time: Sun Aug 31 13:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.04508 seconds
