Home » Eclipse Projects » Eclipse Platform » Configuration APIs
Configuration APIs [message #331636] Mon, 15 September 2008 04:21 Go to next message
Originally posted by: ahmad.alobaidy.gmail.com
is there any APIs to change the settings in the eclipse.ini file?
to change the interface language from english to arabic for example for
example?
Re: Configuration APIs [message #331641 is a reply to message #331636] Mon, 15 September 2008 08:08 Go to previous messageGo to next message
> example?
Check out
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/reference/misc/runtime-options.html
You should be able to change the language using the -nl option
PW
Paul Webster
Re: Configuration APIs [message #331659 is a reply to message #331641] Mon, 15 September 2008 20:28 Go to previous message
Sorry for not being clear.
What I meant is having APIs to change the eclipse.ini setting from within
the code...
I want to add perefererances page which allow the user to choose the UI
language of the program.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:galjjb$gnc$2@build.eclipse.org...
>> example?
> Check out
> PW
> Paul Webster
Previous Topic:ClassNotFoundException (org.eclipse.swt.widgets.Composite) when running the Testing Framework
Next Topic:JDT Debugger Big Slowdown
Current Time: Sat Nov 29 11:40:16 EST 2025
Powered by FUDForum. Page generated in 0.04113 seconds
