Home » Eclipse Projects » Eclipse Platform » JDT Debugger Big Slowdown
JDT Debugger Big Slowdown [message #331614] Sun, 14 September 2008 00:39 Go to next message
I have java code that takes 6 seconds to run in Eclipse normally and 200
to run in the debugger. The code calls a JRE method a million times and
that method internally throws and catches an exception.
I reproduced this with a quick junit test (code below). When I click
run in Eclipse it takes 3.877 seconds. When I click debug it takes
144.452 seconds.
I am not surprised there is a slowdown, but this is huge! Is this an
overhead caused by JDI, or is it due to the Eclipse debugger? Any ideas
to workaround it? e.g. turn off some feature?
Will
import org.junit.Test;
public class ExceptionDebugTest {
@Test
public void run() {
for (long i = 0; i < 1000000L; i++) {
try {
throw new Exception();
catch (Exception e) {
Re: JDT Debugger Big Slowdown [message #331616 is a reply to message #331614] Sun, 14 September 2008 02:15 Go to previous messageGo to next message
Make sure you don't have any conditional breakpoints. They can cause
lots of overhead. Clear all of your breakpoints if there is any doubt.
Normally running with debug and no breakpoints is pretty much as fast
as the real thing.
> 144.452 seconds.
> Will
> @Test
> public void run() {
> try {
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: JDT Debugger Big Slowdown [message #331623 is a reply to message #331616] Sun, 14 September 2008 16:13 Go to previous messageGo to next message
Thanks for the response. Actually I am running in the debugger with no
breakpoints at all. I even tried unchecking everything in the
Java\Debug preference page and still there is the same 30x slowdown.
> as the real thing.
>> 200 to run in the debugger. The code calls a JRE method a million
>> times and that method internally throws and catches an exception.
>> 144.452 seconds.
>> ideas to workaround it? e.g. turn off some feature?
>> Thanks,
>> Will
>> @Test
>> public void run() {
>> try {
Re: JDT Debugger Big Slowdown [message #331658 is a reply to message #331623] Mon, 15 September 2008 20:00 Go to previous messageGo to next message
The same behavior happens in IntelliJ, so I guess this is not caused by JDT.
>> doubt. Normally running with debug and no breakpoints is pretty much
>> as fast as the real thing.
>>> 144.452 seconds.
>>> Thanks,
>>> Will
>>> @Test
>>> public void run() {
>>> try {
Re: JDT Debugger Big Slowdown [message #331661 is a reply to message #331658] Mon, 15 September 2008 20:32 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
> JDT.
>> no breakpoints at all. I even tried unchecking everything in the
>>>> click run in Eclipse it takes 3.877 seconds. When I click debug it
>>>> takes 144.452 seconds.
>>>> Thanks,
>>>> Will
>>>> @Test
>>>> public void run() {
>>>> try {
My guess is that when you aren't running in debug mode, the jit compiler
is kicking in and optimizing out most of your code since it doesn't
actually do anything. When running in debug mode, the jit compiler
isn't kicking in.
Jit side effects are something you have to keep in mind when attempting
to write benchmark code such as this.
See if the following behaves differently:
public void run() {
int exceptionCount = 0;
try {
exceptionCount++;
System.out.println("Caught " + exceptionCount + " exceptions.");
Re: JDT Debugger Big Slowdown [message #331663 is a reply to message #331661] Mon, 15 September 2008 21:17 Go to previous message
David Wegener wrote:
>> by JDT.
>>>> cause lots of overhead. Clear all of your breakpoints if there is
>>>> any doubt. Normally running with debug and no breakpoints is pretty
>>>> much as fast as the real thing.
>>>>> and 200 to run in the debugger. The code calls a JRE method a
>>>>> million times and that method internally throws and catches an
>>>>> exception.
>>>>> an overhead caused by JDI, or is it due to the Eclipse debugger?
>>>>> Any ideas to workaround it? e.g. turn off some feature?
>>>>> Thanks,
>>>>> Will
>>>>> @Test
>>>>> public void run() {
>>>>> try {
> isn't kicking in.
> public void run() {
> try {
> exceptionCount++;
Thanks for the idea, and good point about the JIT compiler. But I
tested your code and still see the same behavior. Even just running
java -agentlib:jdwp=transport=dt_shmem,server=y,suspend=n Foo
has the slowdown.
Previous Topic:Configuration APIs
Next Topic:Multiple eclipse version support.
Current Time: Sat Nov 08 20:29:52 EST 2025
Powered by FUDForum. Page generated in 0.07051 seconds
