Home » Eclipse Projects » Eclipse Platform » [CommonNavigator] Setting a IElementComparer
[CommonNavigator] Setting a IElementComparer [message #331607] Fri, 12 September 2008 12:01 Go to next message
Hi!
Is there a way to set ElementComparer for the CNF?
my situation is the following:
An editor is setting an Gef-graphicalViewer as SelectionProvider. This
viewer is posting EditParts as selections.
The CN shows the modelElements stored in the editParts. In order to enable
the linking between the editor an the common navigator the equals/hashcode
method of the two objects has to be identical. However, for various
business reasons I cannot change the eq/hc methods. Thus my idea was to
set an IElementComparer. However this doesn't seem to be supported by the
CNF.
Any ideas?
Bernd
Re: [CommonNavigator] Setting a IElementComparer [message #331890 is a reply to message #331607] Fri, 26 September 2008 12:44 Go to previous message
(sorry for the delay in the reply)
Can you not use a the link helper extension point?
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/reference/extension-points/org_eclipse_ui_navigator_ linkHelper.html
Or am I missing the point?
Francis
Bernd Kolb wrote:
> Hi!
> viewer is posting EditParts as selections. The CN shows the
> modelElements stored in the editParts. In order to enable the linking
> between the editor an the common navigator the equals/hashcode method of
> the two objects has to be identical. However, for various business
> reasons I cannot change the eq/hc methods. Thus my idea was to set an
> IElementComparer. However this doesn't seem to be supported by the CNF.
> Any ideas?
> Best regards,
> Bernd
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:propblems view - open on new problem
Next Topic:Showing perspective-defined wizards in custom navigator
Current Time: Sat Nov 15 14:26:13 EST 2025
Powered by FUDForum. Page generated in 0.44435 seconds
