Home » Eclipse Projects » Eclipse Platform » Obtaining *all* referenced projects (including plugins and external folders)
Obtaining *all* referenced projects (including plugins and external folders) [message #331500] Wed, 10 September 2008 10:46 Go to next message
at the moment, our plugin uses getReferencedProjects() of IProject to
find out the referenced projects. However, this does not work if
projects in a second runtime Eclipse instance contain references to the
workspace of the "outer" Eclipse instance.
How do I get all referenced projects including references to external
folders?
Patrick
Patrick Schönbach
Software Engineer
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
web: http://www.itemis.de
mail: schoenbach@itemis.de
xing: https://www.xing.com/profile/Patrick_Schoenbach
itemis AG
Schauenburgerstraße 116
24118 Kiel
Germany
Rechtlicher Hinweis:
Amtsgericht Dortmund, HRB 20621
Vorstand: Wolfgang Neuhaus, Jens Wagener, Dr. Georg Pietrek
Aufsichtsrat: Dr. Burkhard Igel(Vors.), Stephan Grollmann, Michael
Neuhaus
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331501 is a reply to message #331500] Wed, 10 September 2008 11:35 Go to previous messageGo to next message
--------------010209090000040208030802
Patrick,
I wonder if you need to consider the dynamic references:
project.getDescription().getDynamicReferences()
Patrick Sch
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331512 is a reply to message #331501] Wed, 10 September 2008 15:58 Go to previous messageGo to next message
On Wed, 10 Sep 2008 11:35:34 -0400, Ed Merks wrote:
> Patrick,
This method returns an empty array in my case.
Patrick
Patrick Schönbach
Software Engineer
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331513 is a reply to message #331512] Wed, 10 September 2008 17:20 Go to previous messageGo to next message
--------------090708090609040109060908
Patrick,
I have a feeling that this is just the way it works. The referenced
IProjects, if they aren't actually in your workspace, are not going to
be accessible via the IProject anyway, even if the methods did return
them (and the methods do hint that they would). Maybe I should ask more
generally what you're trying to do? For sure you won't be able to
access these other projects via the Eclipse resource APIs...
Patrick Sch
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331515 is a reply to message #331513] Wed, 10 September 2008 18:05 Go to previous messageGo to next message
On Wed, 10 Sep 2008 17:20:08 -0400, Ed Merks wrote:
> Patrick,
Actually, my goal is to find and load a referenced Ecore. The current
code works, except for external folders, and we want to fix this. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244516
Patrick
Patrick Schönbach
Software Engineer
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331519 is a reply to message #331515] Thu, 11 September 2008 06:15 Go to previous messageGo to next message
--------------010800090507050505030401
Patrick,
I see that https://bugs.eclipse.org/bugs/show_bug.cgi?id=246764 is
resolved the way I would have expected...
It sounds like this issue is related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=220218
Any mechanism designed to walk through IProject/IJavaProject is simply
not going to work at all if the things you want to search are not in the
workspace so definitely you need to take a different direction.
I'm not sure if things like
EcorePlugin.getEPackageNsURIToGenModelLocationMap() help; that would
help only if the .ecore files you're trying to locate are those of
models that are installed in the runtime itself...
In the Ecore editor we do the following when setting up the editor to
read the Ecore model
public void createModel()
editingDomain.getResourceSet().getURIConverter().getURIMap() .putAll(EcorePlugin.computePlatformURIMap());
What this does is ensure that references of the form
platform:/resource/<project-name>/... are redirected to
platform:/plugin/<plugin-id>/... (where project name and plugin-id are
expected to match) if the project isn't in the workspace but there is a
generated modeling in the runtime that has registered its model/*.ecore
serialized version. And also references of the form
platform:/plugin/<plugin-id>/... are redirected to
platform:/resource/<project-name>/... so that even for registered
models, the workspace version takes precedence... I'm not sure if this
approach would help...
In general, it seems to me that finding Ecore models should not rely on
project references or even on plugin dependencies. Any registered model
should be available...
Patrick Sch
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331522 is a reply to message #331519] Thu, 11 September 2008 07:23 Go to previous messageGo to next message
It might help or it might not. But I am not sure yet, that I fully
understand how this works. Could you please elaborate?
Patrick
Patrick Schönbach
Software Engineer
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331523 is a reply to message #331522] Thu, 11 September 2008 08:13 Go to previous messageGo to next message
--------------070008020002020203070806
Patrick,
Generated models produce this registration:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri="http://www.example.com/Library"
class="com.example.library.impl.LibraryPackageImpl"
*genModel="model/Library.genmodel"*/>
</extension>
When we populate the package registry, we also populate
EcorePlugin.getEPackageNsURIToGenModelLocationMap. This lets us know
for each registered package where it's development time GenModel is and
hence where its development time .ecore model is (because that GenModel
references it). From that information we can determine all the plugins
that have GenModels and from that we can build URI maps that redirect
non-existing projects to their plugins and plugins to project in the
work space that takes precedence. Looking at the source code and
Javadoc for these EcorePlugin methods should help understand what they
are doing.
Maybe you could elaborate on the problem you are trying to solve?
Patrick Sch
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331548 is a reply to message #331523] Thu, 11 September 2008 12:38 Go to previous messageGo to next message
Well, actually the problematic code location looks as follows:
private EPackage[] getMetamodelsForProjectInternal(IJavaProject
project, Set<String> visited) {
if (visited.contains(project.getProject().getName()))
return new EPackage[0];
visited.add(project.getProject().getName());
ProjectAnalyzer projectAnalyzer =
getProjectAnalyzer(project.getProject());
if (projectAnalyzer == null) {
// wait if analyzation is currently executed
while (projectAnalyzer.getState() == Job.RUNNING ||
projectAnalyzer.getState() == Job.WAITING) {
try {
Thread.sleep(500l);
if (EmfToolsPlugin.trace)
System.out.println("Waiting 500ms for ProjectAnalyzer of project "
+ project.getProject().getName() + " to finish.");
} catch (InterruptedException e) {
EmfToolsLog.logError(e);
Map<String, EPackage> packages = new HashMap<String,
EPackage>(projectAnalyzer.getNamedEPackageMap());
try {
for (IProject p : project.getProject().getReferencedProjects()) {
IJavaProject jp = JavaCore.create(p);
EPackage[] ps = getMetamodelsForProjectInternal(jp, visited);
for (EPackage package1 : ps) {
if (!packages.containsKey(package1.getNsURI())) {
packages.put(package1.getNsURI(), package1);
} catch (CoreException e) {
return packages.values().toArray(new
EPackage[packages.values().size()]);
The ProjectAnalyzer mentioned in the code, tries to obtain an IResource
to the found Ecore file. The problem is that all this does not work, if
the Ecore model is located in an external folder.
Patrick
Patrick Schönbach
Software Engineer
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331552 is a reply to message #331548] Thu, 11 September 2008 13:17 Go to previous messageGo to next message
--------------050901010503060705000701
Patrick,
Comments below.
Patrick Sch
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331554 is a reply to message #331552] Thu, 11 September 2008 13:42 Go to previous messageGo to next message
On Thu, 11 Sep 2008 13:17:39 -0400, Ed Merks wrote:
> Yes, and it's simply impossible to make this work. At some point I hope
> to find time to be able to build a package registry that's able to work
> with the target platform as in that EMF bugzilla I referenced. But
> unless you change your design not to rely on everything being in the
> workspace, there's really nothing you can do...
Ok. Is there currently a possible design that would be able to find
models in the workspace, inside deployed plugins, *and* external
folders?
Patrick Schönbach
Software Engineer
itemis AG
24118 Kiel
Germany
Neuhaus
Re: Obtaining *all* referenced projects (including plugins and external folders) [message #331561 is a reply to message #331554] Thu, 11 September 2008 14:27 Go to previous message
--------------050008010306010104000906
Patrick,
In the workspace you could do what you have now. In deployed plugins,
it's possible to force the plugin URL to be converted to a file URL, and
of course that turns it into the final case of pawing through the file
system directly. It's probably good to take a step back and look
consider very carefully how what's being done here is similar to the way
PDE manages and provides access to the target platform... You might
want to treat the problem you're trying to fix as a short term
limitation. Perhaps when I'm in Germany the week of Oct 13th we can
discuss the design choices...
Patrick Sch
Previous Topic:same package in two different bundles: a problem?
Next Topic:How to get rid of "Run as...,Debug As" in my context menu
Current Time: Sat Nov 22 13:02:05 EST 2025
Powered by FUDForum. Page generated in 0.05927 seconds
