Home » Eclipse Projects » Eclipse Platform » <visibleWhen checkEnabled=true/> not always working
<visibleWhen checkEnabled=true/> not always working [message #331479] Tue, 09 September 2008 11:46 Go to next message
I've checked that the <visibleWhen checkEnabled=true/> for a command
inside a menuContribution works ok when inserted inside the main pull down
menu (i.e. menu:window?after=additions), but the toolbar item is always
hidden when inserted inside the main toolbar
(toolbar:org.eclipse.ui.main.toolbar?after=additions).
The enablement state of the command depends only on the active view part.
Some views register a handler for the command, whereas for others there is
no handler.
Is this a known bug?
Re: <visibleWhen checkEnabled=true/> not always working [message #331531 is a reply to message #331479] Thu, 11 September 2008 09:11 Go to previous message
David Pérez wrote:
> down menu (i.e. menu:window?after=additions), but the toolbar item is
> always hidden when inserted inside the main toolbar
org.eclipse.ui.main.toolbar is the location of the main coolbar :-)
which is a toolbar container. You need to create a toolbar in that menu
contribution and then add commands to it.
PW
Paul Webster
Previous Topic:Source and Test Folder
Next Topic:Is there a "Workbench User Guide" for RCP?
Current Time: Mon Sep 01 02:45:31 EDT 2025
Powered by FUDForum. Page generated in 0.22200 seconds
