Home » Eclipse Projects » Eclipse Platform » Subclipse on Ganymede, comparison editor fails most of the time?
Subclipse on Ganymede, comparison editor fails most of the time? [message #331464] Mon, 08 September 2008 17:07 Go to next message
On two different copies of Ganymede I find that the Synchronize "open in
compare editor" fails frequently. The editor is a blank panel. Seems to
work ok for Java, but fails a lot for Javascript (or is that just a
sampling error on my part?).
Anyone else see this? Is it just Javascript?
John
Re: Subclipse on Ganymede, comparison editor fails most of the time? [message #331465 is a reply to message #331464] Mon, 08 September 2008 17:17 Go to previous messageGo to next message
Is there anything in your log... like an exception coming from the
Compare framework?
~ Chris
Re: Subclipse on Ganymede, comparison editor fails most of the time? [message #331482 is a reply to message #331465] Tue, 09 September 2008 14:45 Go to previous message
>> in compare editor" fails frequently. The editor is a blank panel.
>> Seems to work ok for Java, but fails a lot for Javascript (or is that
>> just a sampling error on my part?).
> Compare framework?
> Cheers,
> ~ Chris
Yep, thanks, I opened this bug with the exception and call stack:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246669
Seems to be caused by JSDT. If anyone has a workaround that would be
great. I can't use Ganymede for commits without compare editor so its
back to tortoiseSVN for now...
jjb
Previous Topic:Is there a Feature Cleanup tool?
Next Topic:WorkbenchPage addPropertyChangeListener is deprecated why? and what to do?
Current Time: Sun Aug 31 02:33:28 EDT 2025
Powered by FUDForum. Page generated in 0.07102 seconds
