Home » Eclipse Projects » Eclipse Platform » Menu extensions
Menu extensions [message #331395] Thu, 04 September 2008 12:57 Go to next message
I'm having some trouble with menus/commands..
What I want to do is have some menu items (commands) "disabled" - ie
greyed out - when the current selection is not a suitable object for those
actions.
I have created a simple expression:
<extension
point="org.eclipse.core.expressions.definitions">
<definition
id="org.eclipse.tigerstripe.workbench.ui.base.TSProjectSelected ">
<iterate>
<adapt
type="org.eclipse.core.resources.IResource">
<test
property="org.eclipse.core.resources.projectNature"
value="org.eclipse.tigerstripe.workbench.base.tigerstripeProject ">
</test>
</adapt>
</iterate>
</definition>
</extension>
I know this works because I can use to make a menu entry disappear
(although that's not really what I want to do...):
<menu id="org.eclipse.tigerstripe.ui.main.menu.import"
label="Import...">
<visibleWhen
checkEnabled="false">
<reference
definitionId="org.eclipse.tigerstripe.workbench.ui.base.TSProjectSelected ">
</reference>
</visibleWhen>
</menu>
But if I try to use it to disable my commands then they get greyed out and
never come back..
<extension point="org.eclipse.ui.handlers">
<handler
class=" org.eclipse.tigerstripe.workbench.ui.internal.handlers.Tiger stripeCommandHandler "
commandId="org.eclipse.tigerstripe.workbench.ui.base.generate ">
<enabledWhen>
<reference
</reference>
</enabledWhen>
</handler>
</extension>
I guess I am missing a step somewhere but can't quite work out what it
is...
My Handler is very basic at the moment - it only implements the
execute(..) command.
Can anyone point me in the right direction?
Thanks in advance,
Richard
Re: Menu extensions [message #331398 is a reply to message #331395] Thu, 04 September 2008 13:58 Go to previous messageGo to next message
Using org.eclipse.ui.handlers seems to be heading the right direction.
Some things I can think of: Make sure your command doesn't declare a
default handler. Are your menu contributions in the main menu or in a
popup?
What if you put your core expression definition directly in the enabledWhen?
PW
Paul Webster
Re: Menu extensions [message #331402 is a reply to message #331398] Thu, 04 September 2008 14:51 Go to previous message
Hi Paul,
I did have a defaultHandler, and removing it made this work correctly!
The defaultHandler was actually the same class as my handler, so I'm a
little confused but at least I seem to abe to make things work correctly
now!
Many thanks
Richard
> popup?
> PW
Previous Topic:Value returned by IConfigurationElement.getAttribute() was not translated
Next Topic:uitest throws ClassCastException
Current Time: Wed Jul 16 07:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.42077 seconds
