Home » Eclipse Projects » Eclipse Platform » returning an exit code
returning an exit code [message #331387] Thu, 04 September 2008 04:59 Go to next message
Originally posted by: subs._nospam_consertum.com
Does anybody have any suggestions on how I might pass an 'exit code' to
a script that invokes eclipse?
I have written an Eclipse plugin that allows certain operations to be
performed in a 'batch' mode and then exit. This is working. I am trying
to find a way to pass the success/fail status to a shell script that
started Eclipse.
I have tried
System.setProperty("eclipse.exitcode", 999);
workbench.close() ;
but the exit code from the Eclipse executable is always zero. It seems
that Workbench#close() always sets the 'return code' to zero.
I am writing status information to a file, so I could add something to
that, but the script would then need to read the file (which I am trying
to avoid).
I had thought about using environment variables, but there is no way to
set one using Java.
Any other thoughts?
Derek
Re: returning an exit code [message #331433 is a reply to message #331387] Fri, 05 September 2008 15:15 Go to previous message
You will probably need to create your own Application. The workbench is
using IDEApplication. You could probably extend this and have your
start return an Integer(999)
-Andrew
Derek wrote:
> started Eclipse.
> I have tried
> workbench.close() ;
> to avoid).
> set one using Java.
> Any other thoughts?
> Thanks
Previous Topic:how to select row number in JFace TableViewer
Next Topic:[P2] Problem creating repository with .product when exporting for multiple platforms
Current Time: Mon Nov 10 07:22:29 EST 2025
Powered by FUDForum. Page generated in 0.03024 seconds
