Home » Eclipse Projects » Eclipse Platform » Accessing SharedImages in plugin.xml (for ex. org.eclipse.ui.menus)
Accessing SharedImages in plugin.xml (for ex. org.eclipse.ui.menus) [message #331352] Wed, 03 September 2008 05:20 Go to next message
Originally posted by: bach2kCUT_THIS.gazeta.pl
I have following command declaration
<extension point="org.eclipse.ui.menus">
<menuContribution locationURI="popup:pl.some.menu">
<command commandId="pl.some.page.delete"
icon="icons/delete.gif"
label="%page.delete">
</command>
I am using my copy of delete icon. I would like to use shared image instead,
like:
PlatformUI.getWorkbench().getSharedImages().getImage(IShared Images.IMG_TOOL_
DELETE)
How can I use ISharedImages.IMG_TOOL_DELETE in my command declaration
best regards
krzysztof
Re: Accessing SharedImages in plugin.xml (for ex. org.eclipse.ui.menus) [message #331366 is a reply to message #331352] Wed, 03 September 2008 12:55 Go to previous messageGo to next message
That isn't currently supported. Can you use shared images in actionSet
actions? Is there already a way to specify them?
Please open an enhancement against Eclipse Platform UI at
https://bugs.eclipse.org/bugs/
PW
Paul Webster
Re: Accessing SharedImages in plugin.xml (for ex. org.eclipse.ui.menus) [message #331392 is a reply to message #331366] Thu, 04 September 2008 11:05 Go to previous messageGo to next message
Hello
I create a bug report about this enhancement :
http://bugs.eclipse.org/bugs/show_bug.cgi?id=246224
Thomas
Re: Accessing SharedImages in plugin.xml (for ex. org.eclipse.ui.menus) [message #331419 is a reply to message #331366] Fri, 05 September 2008 07:25 Go to previous message
dont know.
I only found that I can use "org.eclipse.ui.edit.delete" as commandId
in my declaration thus it gets image from command declared.
But this doesn't solve the problem.
I think "org.eclipse.ui.edit.delete" defined icon is not
(and I already use this command for different purpose anyway).
The enhancement would be usefull.
best regards
krzysztof
Previous Topic:How to contribute menu item to Package Explorer
Next Topic:Re: [databinding] bind to a null EReference
Current Time: Tue Nov 04 21:08:33 EST 2025
Powered by FUDForum. Page generated in 0.24152 seconds
