Home » Eclipse Projects » Eclipse Platform » How to override the initial input of the CommonNavigator
How to override the initial input of the CommonNavigator [message #331350] Tue, 02 September 2008 23:07 Go to next message
My project have 2 views, one is the resource navigator, another is a custom
common navigator used to show mail account and it's folders in tree
structure just like Outlook Express or other mail clients. The later view I
called "Mails navigator".
Because the above 2 common navigators use 2 different input, one is
IWorkspaceRoot, another is an IMailRepository(an Interface defined in my
model package), so, I make an subclass from CommonNavigator to override the
initial input and return an IMailRepository object. I use this class as the
contentProvider of navigatorContent extension of the "Mails navigator" view,
and use the CommonNavigator class for the "Resource Navigator" view just
like standard way. But the CommonNavigator API document said: "This class is
not intended to be subclassed by clients. ". So, I think, the subclass is
not the right way for resolve this issue. This is my first question: How to
override the initial input of the CommonNavigator?
The second question. When I make the subclass, done as above, and run the
application. Everything are look likes OK, expect for one thing: When I move
the mouse on to the tab title of the "Mails Navigator" view, a tooltip with
an error message was shew: "Error: no label provider for
cn.com.dwservice.mail.impl_fs.MailRepositoryImpl@14fcd9a". I known,
"MailRepositoryImpl" just the class of the result value returned by
MailNavigator.getInitialInput(). But I dont known why it said "no label
provider", I have been specified the labelProvider, and at the runtime, the
navigator treeview shows the treeNode's label correcttly. Why?
Yau K.J.
Re: How to override the initial input of the CommonNavigator [message #331351 is a reply to message #331350] Wed, 03 September 2008 04:07 Go to previous messageGo to next message
Yau K.J. wrote:
The way you did it is the only way you can at the moment. This bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=145233
addresses the issue. Look for it to be fixed in 3.5M2 or M3.
Are you using working sets? If so, it's likely that it's this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239465
If you are not using working sets, please file a bug against
Eclipse/Platform UI.
http://wiki.eclipse.org/Platform_UI/FAQ#How_do_I_report_a_bu g.3F
> Yau K.J.
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: How to override the initial input of the CommonNavigator [message #331377 is a reply to message #331351] Wed, 03 September 2008 22:55 Go to previous message
Hi Francis Upton,
Thank you very much!
I am not using worksets. The fact is the second problem is my fault. I just
traced into the
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.getStyledText(),
then I found, I have not returned the text for the IMailRepository object
in my label provider's getStyledText() method, this cause the
NavigatorContentServiceLabelProvider return the error message.
Haha, my problem was resolved, Thank you again!
Yau K.J.
Previous Topic:Unable to find plug-in: org.eclipse.equinox.launcher.motif.solaris.sparc_1.0.100.HEAD
Next Topic:Update manager from command line
Current Time: Wed Aug 13 17:11:39 EDT 2025
Powered by FUDForum. Page generated in 0.03432 seconds
