Home » Eclipse Projects » Eclipse Platform » OperationHistoryActionHandler AssertionFailedException: null argument
OperationHistoryActionHandler AssertionFailedException: null argument [message #331346] Tue, 02 September 2008 15:17 Go to next message
Originally posted by: cagiva92.hotmail.com
I'm getting an AssertionFailedException when the below code is called from
my dispose() method. Please let me know if you have any suggestion or if
you know why this is happening. Thanks in advance!
IUndoContext context = getUndoContext();
OperationHistoryFactory.getOperationHistory().dispose(contex t, true, true,
true);
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
org.eclipse.core.commands.operations.AbstractOperation.hasCo ntext(AbstractOperation.java:153)
org.eclipse.ui.operations.OperationHistoryActionHandler$Hist oryListener.historyNotification(OperationHistoryActionHandle r.java:130)
org.eclipse.core.commands.operations.DefaultOperationHistory $2.run(DefaultOperationHistory.java:929)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.commands.operations.DefaultOperationHistory .notifyListeners(DefaultOperationHistory.java:918)
org.eclipse.core.commands.operations.DefaultOperationHistory .notifyRemoved(DefaultOperationHistory.java:1042)
org.eclipse.core.commands.operations.DefaultOperationHistory .internalRemove(DefaultOperationHistory.java:890)
org.eclipse.core.commands.operations.DefaultOperationHistory .flushUndo(DefaultOperationHistory.java:624)
org.eclipse.core.commands.operations.DefaultOperationHistory .dispose(DefaultOperationHistory.java:328)
at abc.yxz.core.plan.Plan.dispose(Plan.java:209)
Re: OperationHistoryActionHandler AssertionFailedException: null argument [message #331365 is a reply to message #331346] Wed, 03 September 2008 12:54 Go to previous message
Ben wrote:
> from my dispose() method. Please let me know if you have any suggestion
> or if you know why this is happening. Thanks in advance!
> true, true);
When you call dispose, you're destroying your applications operation
history. Set a breakpoint in the DefaultOperationHistory.dispose(*) to
find out where else it is being called from. If you are running the
workbench, WorkbenchOperationSupport disposes the operation history on
shutdown.
PW
Paul Webster
Previous Topic:Mapping line numbers in an ISourceLookupParticipant
Next Topic:Classes in a jar within a plugin are not visible to other plugins
Current Time: Mon Jul 21 22:13:35 EDT 2025
Powered by FUDForum. Page generated in 0.05706 seconds
