Home » Eclipse Projects » Eclipse Platform » [Data Binding] Re: Widget [org.eclipse.swt.custom.StyledText] is not supported.
[Data Binding] Re: Widget [org.eclipse.swt.custom.StyledText] is not supported. [message #331339] Tue, 02 September 2008 11:15 Go to next message
Francis ANDRE wrote:
> Hello
> got this exception
> Exception in thread "main" java.lang.IllegalArgumentException: Widget
> at
> org.eclipse.jface.databinding.swt.SWTObservables.observeText (SWTObservables.java:217)
> at databinding.view.View.createShell(View.java:76)
> at databinding.driver.IBM3270$1.run(IBM3270.java:23)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at databinding.driver.IBM3270.main(IBM3270.java:20)
> Why StyledText is not supported while Text is?? (May be it is a stupid
> question but I am a little perplex since a StyledText is somewhat a Text
> too)
I'm copying this to the eclipse.platform newsgroup where Data Binding
questions are usually directed.
Have you looked for or entered a feature request in Bugzilla for that?
It looks like TextObservableValue (which is what
SWTObservables.observeText() delegates to) only relies on
addVerifyListener(), getText(), and setText(), so on the surface it
seems that StyledText support should be doable.
You could always write your own StyledTextObservableValue, of course and
contribute that to the project.
If you enter a feature request into Bugzilla, please post the link here.
Eric
Re: [Data Binding] Re: Widget [org.eclipse.swt.custom.StyledText] is not supported. [message #331467 is a reply to message #331339] Mon, 08 September 2008 19:33 Go to previous message
This is on the table for 3.5, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=131435
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g9jl7l$qnn$1@build.eclipse.org...
>> Hello
>> got this exception
>> at
>> at
>> too)
> Have you looked for or entered a feature request in Bugzilla for that? It
> looks like TextObservableValue (which is what SWTObservables.observeText()
> delegates to) only relies on addVerifyListener(), getText(), and
> setText(), so on the surface it seems that StyledText support should be
> doable.
> Eric
Previous Topic:PDE headless build - Target definition
Next Topic:clipboard paste fails in eclipse 3.4.0
Current Time: Sat Nov 08 15:15:00 EST 2025
Powered by FUDForum. Page generated in 0.03621 seconds
