Home » Eclipse Projects » Eclipse Platform » Source lookup doesn't work when debugging a fragment
Source lookup doesn't work when debugging a fragment [message #331324] Mon, 01 September 2008 10:50 Go to next message
Originally posted by: jamesblackburn+eclipse.mac.com
Hi All,
I've created a fragment which overrides existing platform functionality.
I've added the fragment's jar to the plugin's Bundle-ClassPath and
Eclipse-ExtensibleAPI: true
The code builds and runs as expected - I can verify that my code is
being called. However if I set a breakpoint, the source shown is for
the original plugin, not the fragment (line numbers etc. are out of whack).
In the Debug View's Source Lookup path, the Default grouping shows the
plugin before the fragment. If I remove the default grouping and add
<plugin>.patch before <plugin> I still get the Plugin's source instead
of the fragment's...
Am I doing something wrong or should I file a bug?
James
Re: Source lookup doesn't work when debugging a fragment [message #331326 is a reply to message #331324] Mon, 01 September 2008 12:25 Go to previous messageGo to next message
Originally posted by: zx.code9.com
James Blackburn wrote:
> Hi All,
Can you file a bug for this, this could be an issue with the new source
bundle story.
Thanks!
~ Chris
Re: Source lookup doesn't work when debugging a fragment [message #331327 is a reply to message #331326] Mon, 01 September 2008 12:52 Go to previous message
>> Hi All,
>> functionality. I've added the fragment's jar to the plugin's
>> Bundle-ClassPath and Eclipse-ExtensibleAPI: true
>> whack).
> bundle story.
> Thanks!
Thanks for the reply Chris, I've filed https://bugs.eclipse.org/245893
Interestingly source lookup does work when the class only exists in the
fragment (using either source lookup path of 'Default' or
<plugin>.patch, <plugin>) but still can't convince the thing to show me
the correct class when the it exists in both the fragment and the plugin.
James
> Cheers,
> ~ Chris
Previous Topic:Popup menubarPath for 'New grouping'
Next Topic:How to programmatically waiting for build to complete?
Current Time: Mon Nov 03 02:28:42 EST 2025
Powered by FUDForum. Page generated in 0.06879 seconds
