Home » Eclipse Projects » Eclipse Platform » Menu item visibleWhen a handler is active
Menu item visibleWhen a handler is active [message #331197] Wed, 27 August 2008 19:20 Go to next message
I want to make menu items (added using the menus extension point)
visible when a handler for its command is active.
I saw in the wiki a plan for
<visibleWhen handler="true"/>
but this is not yet implemented, right?
Is there a simple trick to mimic this behavior?
Teddy
Re: Menu item visibleWhen a handler is active [message #331248 is a reply to message #331197] Thu, 28 August 2008 11:04 Go to previous message
The best you can do in 3.4 is to use checkEnabled="true" with
visibleWhen. Your menu item will be visible when the command is enabled.
PW
Paul Webster
Previous Topic:Bug? closing doesn't save the state of inactive perspective correctly?
Next Topic:Which Adapters available?
Current Time: Wed Nov 05 15:24:48 EST 2025
Powered by FUDForum. Page generated in 0.03657 seconds
