Home » Eclipse Projects » Eclipse Platform » BusyIndicator vs ProgressMonitorDialog
BusyIndicator vs ProgressMonitorDialog [message #331189] Wed, 27 August 2008 14:44 Go to next message
WinXP; R3.3
I seem to recall that there is already some way to get the following
behavior in Eclipse (but searching the help and these newsgroups turned
up no answer):
I have a long-running operation, which in some cases will complete in
(say) 1-2 sec, and in others will complete in more like 30-60 sec. It
has not yet proven possible to compute, in advance and reliably, how
long a given case will run.
So I would like to have the busy cursor appear, and then (if the
operation lasts longer than some time), to have the progress-monitor
dialog open.
I know how to do the first:
BusyIndicator.showWhile(someDisplay, someRunnable);
And the second looks like this:
try {
new ProgressMonitorDialog(someShell).run(false, false,
someRunnableWithProgress);
} catch (InvocationTargetException ite) {
logError(ite.getCause());
} catch (InterruptedException ie) {
; // since 'cancel' == false, this should never happen
Is there any built-in Eclipse way? Or is it a matter of my writing a
multithreaded timer, that monitors a Job, and then creates the
ProgressMonitorDialog on the fly if more than the specified time has
gone by?
thanks,
Paul
Re: BusyIndicator vs ProgressMonitorDialog [message #331191 is a reply to message #331189] Wed, 27 August 2008 14:54 Go to previous messageGo to next message
PlatformUI.getWorkbench().getProgressService().
Tom
Paul Th. Keyser schrieb:
> WinXP; R3.3
> up no answer):
> dialog open.
> try {
> gone by?
> thanks,
> Paul
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: BusyIndicator vs ProgressMonitorDialog [message #331193 is a reply to message #331191] Wed, 27 August 2008 15:33 Go to previous messageGo to next message
> Tom
Thanks for the quick reply; that looks familiar, now that I see it, and
I'm sure it is what I was thinking of. In some prior project, I believe
I used it with success -- but this time, the ProgressMonitorDialog only
appears in the last about 0.3 secs of the operation, no matter how long
the operation takes ...
Presumably my operation is doing something unexpected by the PlatformUI
-- any clues as to what sorts of things might be causing such a problem?
thanks,
Paul
Re: BusyIndicator vs ProgressMonitorDialog [message #331201 is a reply to message #331193] Thu, 28 August 2008 00:07 Go to previous messageGo to next message
In your someRunnableWithProgress class, are you calling the
progressMonitor.beginTask() as soon as the run method is called?
- Prakash
www.blog.eclipse-tips.com
Paul Th. Keyser wrote:
>> Tom
> thanks,
> Paul
Re: BusyIndicator vs ProgressMonitorDialog [message #331232 is a reply to message #331201] Thu, 28 August 2008 10:46 Go to previous messageGo to next message
> - Prakash
Yep, the first lines of its run() method are:
if (null != monitor) {
String msg = ...;
monitor.beginTask(msg, IProgressMonitor.UNKNOWN);
right after that the run() method has:
try {
busyCursorWhile(myRunnableWithProgress);
} finally {
monitor.done();
That is the same structure as I have when I use the simple
ProgressMonitorDialog directly.
(I have read the nice article
http://www.eclipse.org/articles/Article-Progress-Monitors/ar ticle.html)
-Paul
Re: BusyIndicator vs ProgressMonitorDialog [message #331255 is a reply to message #331232] Thu, 28 August 2008 11:21 Go to previous messageGo to next message
Originally posted by: mario.winterer.gmx.net
There seems to be something wrong in your code.
You wrote you are calling busyCursorWhile INSIDE your run method?
Your code should look like the following:
IRunnableWithProgress myRunnableWithProgress = new IRunnableWithProgress() {
public void run(IProgressMonitor monitor) {
monitor = (monitor == null) ? new NullProgressMonitor() : monitor;
try {
monitor.beginTask(...);
} finally {
monitor.done();
>> - Prakash
> String msg = ...;
> try {
> } finally {
> monitor.done();
> -Paul
Re: BusyIndicator vs ProgressMonitorDialog [message #331284 is a reply to message #331255] Thu, 28 August 2008 15:15 Go to previous message
Er, sorry, I did not describe what I am doing correctly. Let me try again:
try {
IRunnableWithProgress runnable = makeRunnableWithProgress(...);
busyCursorWhile(runnable);
// and then, the body of the method makeRunnableWithProgress() is:
return new IRunnableWithProgress() {
public void run(final IProgressMonitor monitor)
throws InvocationTargetException, InterruptedException {
String msg = ...;
try {
myLongTask();
} finally {
monitor.done();
-Paul
Previous Topic:Error Log entry: cannot bind to an undefined command
Next Topic:dropdown menu in view toolbar
Current Time: Sun Aug 31 02:33:44 EDT 2025
Powered by FUDForum. Page generated in 0.04088 seconds
