Home » Eclipse Projects » Eclipse Platform » Re: JFace Databinding + EMF + Performance
Re: JFace Databinding + EMF + Performance [message #331144] Tue, 26 August 2008 13:07 Go to next message
Hi Mario,
This a general Databinding question which is better asked on the
platform newsgroup but here's what I know:
1. Asynch-Updates:
JFace Databinding has the concept of Realm which allows to do things out
of the UI-Thread and sync back to the UI using Display#asyncExec().
It also has the idea of a delaying and pooling changes (e.g. in
SWTObservables#observeDelayedValue)
2. Not updateing invisible components:
I think that when a control is hidden one could set its model to target
startegy to UpdateValueStrategy.POLICY_NEVER (though it looks like this
could not be changed after the binding is created) and calling
binding.updateModelToTarget() once the element is shown at a later point
in time.
Tom
Mario Winterer schrieb:
> Hi!
> We've written some kind of data binding framework for our (emf) model
> objects long ago and now I'm wondering if it is possible to replace it
> by the jface databinding framework step by step.
> But I'm very concerned about the performance. Our framework makes use of
> the Forms API's concept to refresh stale ui components only if they are
> visible (that is if their form part is visible). Apart from that we are
> able to delay the refreshing of certain form parts (using
> Display.asnchExec) to collect all refresh requests in the meantime and
> do one single refresh at the end. Without these concepts, our complex
> model manipulations would result in an ui update stakkato with horrible
> performance (especially because some operations might change features
> more than once in one single model transaction)...
> Are there any similar concepts in the JFace databinding framework,
> especially in conjunction with emf?
> I hope this is the correct newsgroup for this question...
> Mario
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: JFace Databinding + EMF + Performance [message #331145 is a reply to message #331144] Tue, 26 August 2008 13:16 Go to previous messageGo to next message
Originally posted by: mario.winterer.gmx.net
Wow. Thanks for your quick response! You've just brought me to have a
closer look at jface databinding.
Sorry for the wrong newsgroup!
Tom Schindl schrieb:
> Hi Mario,
> 1. Asynch-Updates:
> in time.
> Tom
>> Hi!
>> of the Forms API's concept to refresh stale ui components only if they
>> are visible (that is if their form part is visible). Apart from that
>> we are able to delay the refreshing of certain form parts (using
>> horrible performance (especially because some operations might change
>> features more than once in one single model transaction)...
>> Thanks,
>> Mario
Re: JFace Databinding + EMF + Performance [message #331147 is a reply to message #331145] Tue, 26 August 2008 13:28 Go to previous message
Hi Mario,
If you are interested in different Databinding-Concepts in conjunction
with EMF. I'm just writing an medium complex RCP/EMF/Teneo/CDO/...
enabled example application [1, 2]. I plan on accompanying the whole
with a "book" describing the concepts behind these technologies.
I'm quite sure that you can use Eclipse-Databinding and if something is
not already provided as I have learned in the past the library is
designed in a way that you could add it yourself when digging in.
Tom
[1] http://tom-eclipse-dev.blogspot.com/2008/08/writing-ctreecom bo-widget.html
[2] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/
>> Hi Mario,
>> 1. Asynch-Updates:
>> out of the UI-Thread and sync back to the UI using Display#asyncExec().
>> target startegy to UpdateValueStrategy.POLICY_NEVER (though it looks
>> like this could not be changed after the binding is created) and
>> calling binding.updateModelToTarget() once the element is shown at a
>> later point in time.
>> Tom
>>> Hi!
>>> it by the jface databinding framework step by step.
>>> they are visible (that is if their form part is visible). Apart from
>>> that we are able to delay the refreshing of certain form parts (using
>>> and do one single refresh at the end. Without these concepts, our
>>> complex model manipulations would result in an ui update stakkato
>>> with horrible performance (especially because some operations might
>>> change features more than once in one single model transaction)...
>>> Thanks,
>>> Mario
Previous Topic:Can't export deployable plug-ins or features from Eclipse 3.3.2 on WINDOWS XP
Next Topic:FocusListener on Section
Current Time: Thu Nov 06 17:54:36 EST 2025
Powered by FUDForum. Page generated in 0.05285 seconds
