Home » Eclipse Projects » Eclipse Platform » Changing button state
Changing button state [message #331123] Tue, 26 August 2008 07:22 Go to next message
Is there a way to force eclipse to reevaluate property testers that are
associated with command handlers?
I have implemented state machines to control the enablement of actions in
our UI.
Each action that is controlled by the state machine has a property tester
that checks if a given value is false or true.
To force eclipse to reevaluate those properties we have to create
selection events.
This works as long as we are changing the states and the currently active
view is a selection provider.
The problem is that we are also using the properties view and some more
views that aren't selection providers.
Any suggestions?
Jochen
Re: Changing button state [message #331124 is a reply to message #331123] Tue, 26 August 2008 07:27 Go to previous message
Found the answer here:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 552.html
So I guess I will have to switch to eclipse 3.4
Jochen
Previous Topic:Changing Marker Hilight Color
Next Topic:Buttons
Current Time: Sun Aug 31 02:33:20 EDT 2025
Powered by FUDForum. Page generated in 0.03328 seconds
