Home » Eclipse Projects » Eclipse Platform » Is there any way to control the visibility or enablement of a wizard?
Is there any way to control the visibility or enablement of a wizard? [message #331111] Mon, 25 August 2008 11:55 Go to next message
I want to make a wizard not visible/enable if the current selection is
of some type. But I don't know how. Is there some suggestions?
Thanks.
Re: Is there any way to control the visibility or enablement of a wizard? [message #331129 is a reply to message #331111] Tue, 26 August 2008 09:49 Go to previous messageGo to next message
Dollyn wrote:
> Thanks.
How are you registering the wizard? Let's see the appropriate part of
your plugin.xml...
Eric
Re: Is there any way to control the visibility or enablement of a wizard? [message #331240 is a reply to message #331111] Thu, 28 August 2008 10:55 Go to previous message
Dollyn wrote:
> Thanks.
What kind of wizard? There are 3.
The extensions don't have any kind of enablement clause, although you
can filter the types of selection that your wizard sees.
Normally, you look at the incoming selection and if it is not
appropriate, simply provide a way to update the selection on your first
wizard page (and disable the next/finish button until they do).
PW
Paul Webster
Previous Topic:Undoable Operation Not Working
Next Topic:Bug? closing doesn't save the state of inactive perspective correctly?
Current Time: Tue Jul 22 08:25:59 EDT 2025
Powered by FUDForum. Page generated in 0.07805 seconds
