Home » Eclipse Projects » Eclipse Platform » Activities - Should It Work With A launchDelegates Conribution?
Activities - Should It Work With A launchDelegates Conribution? [message #331110] Mon, 25 August 2008 11:55
I'm in the process of adding activities extensions to some plugins, using a
"isBundleInstalled" test to determine if the contributions in the plugin
should be enabled. It worked fine until I started working on with a plugin
has the org.eclipse.debug.core.launchDelegates extension defined in it. I'm
unable to remove the launch contribution unless I bind the activity to the
launch that the delegate is associated with. Unfortunatly this aslo removes
the base launch from other areas of the UI. Does anyone know if there's a
limitation here, or if it should work???
Previous Topic:Build Targets Disapear after Workbench restart
Next Topic:[Databinding] Trigger validation via my code
Current Time: Thu Jul 17 19:30:15 EDT 2025
Powered by FUDForum. Page generated in 0.03508 seconds
