Home » Eclipse Projects » Eclipse Platform » Popup menubarPath for 'New grouping'
Popup menubarPath for 'New grouping' [message #331108] Mon, 25 August 2008 10:22 Go to next message
Originally posted by: jamesblackburn+eclipse.mac.com
Hi All,
I'm trying to add an action to the navigator / resources / 'C/C++
projects' view to the group which contains 'New > ...' , Go Into etc.
I've tried setting menubarPath to 'group.new'. This creates a new
grouping. If add '/additions' I get an invalid Menu Extension Error.
Setting a breakpoint in PluginActionBuilder.contributeMenuAction(...),
where the exception is generated, I see that the menu manager that
contributes the 'New > ...' wizards has an id of null, as does the
GoInto Action and the separators between them.
Other contributed separators have ids such as 'team.main' &
org.eclipse.cdt.make.ui.menu. I can successfully contribute to these
locations, as well as to the generic 'additions'.
So the question is:
How do I contribute an action to the new group in the navigator popup menu?
James
Re: Popup menubarPath for 'New grouping' [message #331238 is a reply to message #331108] Thu, 28 August 2008 10:49 Go to previous messageGo to next message
Those are normally done using the perspective or
org.eclipse.ui.perspectiveExtensions. You basically want to add a "new
shortcut". That's the data that is used when populating that menu.
PW
Paul Webster
Re: Popup menubarPath for 'New grouping' [message #331325 is a reply to message #331238] Mon, 01 September 2008 10:59 Go to previous message
Thanks Paul. I was hoping not to use something as heavyweight as a
Wizard, but will give it a go.
James
Previous Topic:Focus always on detached console...
Next Topic:Source lookup doesn't work when debugging a fragment
Current Time: Tue Nov 04 16:20:04 EST 2025
Powered by FUDForum. Page generated in 0.04630 seconds
