Home » Eclipse Projects » Eclipse Platform » dropdown menu in view toolbar
dropdown menu in view toolbar [message #331005] Wed, 20 August 2008 21:16 Go to next message
Originally posted by: marc.esher.comcast.net
Greetings all.
I'd like to add a dynamic dropdown menu into the toolbar of my view,
similar to the "test history" dropdown in the junit view. My question is, is
there anything special I need to know -- any gotchas -- about creating menus
dynamically every time the dropdown is clicked? Essentially, it'll be a
"history" dropdown that shows a last XXX items. so that menu can't be
static.
I seem to remember reading/hearing something about a memory leak in this
area; possibly I read it in a bug in bugzilla, but I can't remember.
thanks for any pointers on creating dynamic dropdown menus in views.
best,
marc
Re: dropdown menu in view toolbar [message #331217 is a reply to message #331005] Thu, 28 August 2008 10:22 Go to previous messageGo to next message
It can be done with commands and menu contributions or
IViewActionDelegates and popupMenus, or simply by adding the appropriate
IAction to the views toolbar during createPartControl().
The first way uses a subclass of CompoundContributionItem and other
IContributionItems, the second 2 ways involve using IMenuCreator and SWT
directly.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: dropdown menu in view toolbar [message #331287 is a reply to message #331217] Thu, 28 August 2008 17:42 Go to previous message
Thanks Paul. I ended up figuring this out and it works quite nicely. I'm
really happy with how easy it was to get it going. One thing I found though
was some code on koders to fix a leak of memory items in dynamic menus, i
believe from the junit test history action. glad i found that.
cheers,
marc
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:g96cl4$4q7$1@build.eclipse.org...
> directly.
> Later,
> PW
> Paul Webster
Previous Topic:BusyIndicator vs ProgressMonitorDialog
Next Topic:Enable disable action set
Current Time: Thu Oct 16 20:15:42 EDT 2025
Powered by FUDForum. Page generated in 0.24620 seconds
