Home » Eclipse Projects » Eclipse Platform » [Databinding] Editor (isDirty), PojoObservable and ChangeListener on target to
[Databinding] Editor (isDirty), PojoObservable and ChangeListener on target to [message #330999] Wed, 20 August 2008 16:45 Go to next message
I have an editor which uses Databinding. The model is a Pojo hence I'm
using PojoObservable.
To set the Editor dirty I try to register ChangeListener on the bindings.
IObservableList bindings = bindingContext.getBindings();
for (Iterator<Binding> iterator = bindings.iterator();
iterator.hasNext();) {
Binding object = iterator.next();
object.getTarget().addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
firePropertyChange(IEditorPart.PROP_DIRTY);
As it seems this ChangeListener is called before the model is updated.
Therefore my isDirty check doesn't find changes in the model and doesn't
set the editor to isDirty. The second change then flags the editor as dirty.
Is there a way around this or do I have to change my model from Pojos to
JavaBeans with PropertyChangeListeners?
Best regards, Lars
Re: [Databinding] Editor (isDirty), PojoObservable and ChangeListener on target to [message #331000 is a reply to message #330999] Wed, 20 August 2008 16:51 Go to previous message
Sorry, forget the question. Registering my changeListener to the model
works. PojoObserable also has change support.
Lars Vogel wrote:
> dirty.
> Best regards, Lars
Previous Topic:Unzipping eclipse download requires password?!?
Next Topic:ScrolledForm odd refresh issues
Current Time: Fri Nov 21 04:43:09 EST 2025
Powered by FUDForum. Page generated in 0.89040 seconds
