Home » Eclipse Projects » Eclipse Platform » Re: Simple Jface ListViewer
Re: Simple Jface ListViewer [message #330994] Wed, 20 August 2008 13:10 Go to next message
Zardosht Hodaie wrote:
> Hi all,
> i'm not sure if this post belongs to this group. if not sorry.
> Here is my problem. I want to have a simple ListViewer to show some
> elements. The SWT List shows only Strings and does not contains the
> unerlying Objects. JFace ListViewer needs a model. I thought ok, i make
> a list of elements, and set it as the input to my Jface listViewer. And
> i thought every time a change the input list, the changes should also be
> reflected in viewer. But i don't know what kind of list should i use for
> this. And if i have to write a ContentProvider myself?
> thanks in advance for your help,
> Zardosht.
Note: copying this to the eclipse.platform newsgroup.
I think you can use an ArrayContentProvider to do what you want; it
should handle any array or Collection as input.
Hope this helps,
Eric
Re: Simple Jface ListViewer [message #330997 is a reply to message #330994] Wed, 20 August 2008 14:54 Go to previous messageGo to next message
The viewer won't update themselves when the underlying list changes
(because Java-List don't inform about changes). To make this possible
a) ArrayContentProvider:
List l = ...
viewer.setContentProvider(new ArrayContentProvider());
viewer.setInput(l);
l.add(new ...)
viewer.refresh();
b) Databinding with ObservableListContentProvider
IObservableList l = ...
viewer.setContentProvider(new ObservableListContentProvider());
viewer.setInput(l);
l.add(new ...);
Tom
>> Hi all,
>> make a list of elements, and set it as the input to my Jface
>> listViewer. And i thought every time a change the input list, the
>> changes should also be reflected in viewer. But i don't know what kind
>> of list should i use for this. And if i have to write a
>> Zardosht.
> Hope this helps,
> Eric
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Simple Jface ListViewer [message #330998 is a reply to message #330997] Wed, 20 August 2008 15:03 Go to previous messageGo to next message
> List l = ...
> viewer.setInput(l);
> l.add(new ...)
> viewer.refresh();
> viewer.setInput(l);
> l.add(new ...);
> Tom
>>> Hi all,
>>> kind of list should i use for this. And if i have to write a
>>> Zardosht.
>> Hope this helps,
>> Eric
Thank you for your help. I got it working. Thank you.
Re: Simple Jface ListViewer [message #834439 is a reply to message #330994] Sun, 01 April 2012 20:22 Go to previous message
If you refresh manually don't forget to use listviewer.refresh(true) to update labels as well.
Previous Topic:Eclipse freezes/hangs before Workspace selection
Next Topic:[org.eclipse.ui.navigator.viewer] doesn't work in PackageExplorer
Current Time: Sun Aug 31 21:14:07 EDT 2025
Powered by FUDForum. Page generated in 0.04910 seconds
