Home » Eclipse Projects » Eclipse Platform » Enabling or disabling command handler based on selection
Enabling or disabling command handler based on selection [message #330981] Wed, 20 August 2008 09:19 Go to next message
Originally posted by: nick.allen.onlinehome.de
I am writing a plug-in for Eclipse that integrates with the Bazaar
version control system. I have written my command handlers and used the
menu extension point to insert a "Bazaar" menu into the main eclipse
window. The problem is that my actions are always enabled and I need to
change that based on which files are selected or whether the editor has
focus or not. For selected files I need to check if they are in a parent
(or ancestor) directory that contains a ".bzr" directory and if the
editor has focus I need to check if the file being edited is in such a
directory structure.
The examples show how to use expressions in the XML file for the command
handlers but my condition is too complex to express in XML syntax. I
would like to do this programmatically or to at least write a new
expression class which I can then use in the XML (e.g.
IsUnderBazaarVersionControlExpression).
I have searched for 3 days solid and found nothing appropriate.
How do I do this? Any feedback greatly appreciated.
Many thanks in advance,
Nicholas Allen
Re: Enabling or disabling command handler based on selection [message #331022 is a reply to message #330981] Thu, 21 August 2008 10:47 Go to previous messageGo to next message
Does no-one know how to do this? I would really appreciate any help - I
am new to Eclipse and am getting frustrated that something so easy
should turn out to require so much work and investigation.
Nick
Nicholas Allen wrote:
> Nicholas Allen
Re: Enabling or disabling command handler based on selection [message #331027 is a reply to message #331022] Thu, 21 August 2008 11:17 Go to previous messageGo to next message
I don't know exactly, but have a look at org.eclipse.core.expressions,
that shows you how to provide an expression programatically.
Look at the command stuff in the Wiki as well. I always try to find an
email by Paul Webster if I need to know about this stuff (it has the
best links):
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
You can create a Command programatically and associated an expression
with it.
HTH,
Francis
> Nick
>> Nicholas Allen
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Enabling or disabling command handler based on selection [message #331028 is a reply to message #331027] Thu, 21 August 2008 11:49 Go to previous messageGo to next message
Many thanks for your replies! I will look into these - I hope it turns
out to be fairly easy...
Nick
> best links):
> Paul Webster
> with it.
> HTH,
> Francis
>> Thanks,
>> Nick
>>> Hi,
>>> Nicholas Allen
Re: Enabling or disabling command handler based on selection [message #331055 is a reply to message #331022] Fri, 22 August 2008 05:20 Go to previous message
Not quite sure if this is helpful, but basically you should register a
selection listener with your commands. Depending on the active
selection you may then enable/disable your commands. For finding
files/directories start looking at the Common Navigator pages managed
by Frances.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Previous Topic:Workaround for overriding buildRule?
Next Topic:Add/Edit Watch expression and code completion
Current Time: Sun Nov 23 10:43:21 EST 2025
Powered by FUDForum. Page generated in 0.05304 seconds
