Home » Eclipse Projects » Eclipse Platform » Plugin was not loaded
Plugin was not loaded [message #330977] Wed, 20 August 2008 05:20 Go to next message
Hi!
I have 2 plugin project, one is a RCP application, it defines an extension
point, the other is an "normal" plugin, it defines an extension.
My problem is, when I run the application in eclipse ide environment, it's
OK, the RCP application can dect the extension defined by the plugin,
because in the run configuration I specified launch with these 2 plugin. But
when I export the RCP application to an directory, and also export the
normal plugin to the target plugin directory, then I launch the RCP
application(even if with -clean parameter), the extension contributed by the
normal plugin was not found, it seems the normal plugin was not loaded.
What's wrong in my case?
The MANIFEST.MF of the normal plugin as following:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Cosumer Plug-in
Bundle-SymbolicName: net.yau.test.extensionreg.cosumer;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: net.yau.test.extensionreg.cosumer.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
net.yau.test.extensionreg.master;bundle-version="1.0.0"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Bundle-ActivationPolicy: lazy
PS: I am use Eclipse 3.4.
Thanks!
Yau
Re: Plugin was not loaded [message #330989 is a reply to message #330977] Wed, 20 August 2008 11:49 Go to previous messageGo to next message
Make sure your plug-in is getting installed.
Look at the osgi.bundles property in your
eclipse/configuration/config.ini file.
Generally there are 3 patterns here:
1) All bundles in your product are listed here, make sure your plugin is
in the list.
2) org.eclipse.update.configurator is in the list, it takes care of
scanning the plugins directory and installing what it finds there
3) org.eclipse.equinox.simpleconfigurator is in the list, it reads the
bundles.info file specified with the
org.eclipse.equinox.simpleconfigurator.configUrl property. That
explicitly lists out the bundles that will be installed.
-Andrew
yau wrote:
> Hi!
> Thanks!
> Yau
Re: Plugin was not loaded [message #331008 is a reply to message #330989] Thu, 21 August 2008 00:11 Go to previous messageGo to next message
Thanks for your detailed reply! You are right. The problem is the
org.eclipse.update.configurator plugin was not defined in the my product's
plugin list.
Thank you very much!
Yau
----- Original Message -----
Newsgroups: eclipse.platform
Sent: Wednesday, August 20, 2008 11:49 PM
Subject: Re: Plugin was not loaded
> Look at the osgi.bundles property in your eclipse/configuration/config.ini
> file.
> in the list.
> -Andrew
Re: Plugin was not loaded [message #331009 is a reply to message #330989] Thu, 21 August 2008 00:50 Go to previous messageGo to next message
Thanks for your detaled reply. You are right. The problem is the
org.eclipse.update.configurator plugin was not included in the product
configuration.
Yau
"Andrew Niefer" <aniefer@ca.ibm.com>
??????:g8heeb$rl0$1@build.eclipse.org...
> file.
> in the list.
> -Andrew
Re: Plugin was not loaded [message #331013 is a reply to message #330989] Thu, 21 August 2008 04:54 Go to previous message
I have an other problem, that is the return value of
IConfigurationElement.getAttribute() was not translated.
First, in the extension point shema declaration, I specified
translatable="true" for one attribute("name").
2nd, I specify "%xxx" for the value of "name" attribute in the normal
plugin's extension declaration, and in normal plugin, I created
plugin.properties file and wrote one line xxx=yyyy.
3, When I run the RCP application and call
IConfigurationElement.getAttribute("name"), it return "%xxx" not "yyyy".
But the platform plug-in developer guide said: "Note that any translation
specified in the plug-in manifest file is automatically applied. ".
What's wrong?
Yau
Previous Topic:Building Eclipse 3.4 From Sources Fails
Next Topic:Problem with showing popup message in Custom Install Handler
Current Time: Fri Jul 18 23:32:22 EDT 2025
Powered by FUDForum. Page generated in 0.04777 seconds
