Home » Eclipse Projects » Eclipse Platform » Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work.
Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330969] Tue, 19 August 2008 15:59 Go to next message
Originally posted by: rami.muurimaki.gmail.com
I just "migrated" from Eclipse 3.3 to 3.4 (JEE). For some reason the
Open Type feature is not available. The short CTRL + SHIFT + T cut does
not work either. However Open Resource (CTRL + SHIFT + R) works perfectly.
Have I missed something or is this a bug or what?
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330970 is a reply to message #330969] Tue, 19 August 2008 16:14 Go to previous messageGo to next message
rami kirjoitti:
seems like if I change the workspace location (create new one), the Open
Type is available again and it's working... I guess there is some broken
settings somewhere??
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330972 is a reply to message #330970] Tue, 19 August 2008 17:29 Go to previous messageGo to next message
You probably want to clear out your metadata and start over so to speak,
sounds like some old 3.3 metadata is conflicting with 3.4.
(Or you can go in and re-assign Open Resource in the key binding section,
although that might not be the only issue you run in to)
Emil
"rami" <rami.muurimaki@gmail.com> wrote in message
news:g8f9k4$h3c$1@build.eclipse.org...
> rami kirjoitti:
>> I just "migrated" from Eclipse 3.3 to 3.4 (JEE). For some reason the Open
>> Type feature is not available. The short CTRL + SHIFT + T cut does not
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330973 is a reply to message #330972] Wed, 20 August 2008 01:23 Go to previous messageGo to next message
Emil Crumhorn kirjoitti:
> Emil
>> rami kirjoitti:
Maybe so or something else (bad) happened during the migration.
I think I've had the same .metadata folder from Eclipse version 3.1 :)
so I guess it's about the time to reconfig :)
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330986 is a reply to message #330969] Wed, 20 August 2008 11:16 Go to previous message
What Perspective(s) did you try it in? Not all Perspectives are
configured to include the Open Type command (for example, Resources).
You can configure this via Window > Customize Perspective > Commands.
Hope this helps,
Eric
Previous Topic:Help icon in the NEW_WIZARD_SHORTLIST Contribution item
Next Topic:finding out the commandline equivalent to an eclipse run
Current Time: Tue Nov 04 18:07:12 EST 2025
Powered by FUDForum. Page generated in 0.04120 seconds
