Home » Eclipse Projects » Eclipse Platform » Filtering key binding / Activities support it someway?
Filtering key binding / Activities support it someway? [message #330963] Tue, 19 August 2008 13:08 Go to next message
I am using the extensions meachanism as a way to control access to resources
in our applications here.
The big problem right now is how to filter the shortcut key bindings.
Somebody has some idea about it? I googled a lot today searching for some
information without no clues. I also tried to filter all the possible ids
inside the key bindinds definition without success.
Thanks in advance,
Marcelo
Re: Filtering key binding / Activities support it someway? [message #330968 is a reply to message #330963] Tue, 19 August 2008 15:07 Go to previous messageGo to next message
Marcelo Alcantara wrote:
AFAIK the filtering is not applied against keybindings. You might have
to go in and delete them yourself. There's no easy API for
adding/removing keybindings (it's an expensive operation) but at login
you might be able to modify them. Check out IBindingService
BTW: you make system bindings disappear by *adding* a delete binding :-)
Check out how the KeysPreferencePage does it.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Filtering key binding / Activities support it someway? [message #334262 is a reply to message #330963] Thu, 29 January 2009 13:32 Go to previous message
--------------070405060508060707000609
Content-Type: text/plain; charset=UTF-8; format=flowed
Marcelo Alcantara schrieb:
> Thanks in advance,
> Marcelo
Execution of commands started by bindings can be denied with the
attached patch. If you want to discard certain bindings within the
preferences take a look at BindingModel.
Jens
name="patchBindings.txt"
Content-Disposition: inline;
filename="patchBindings.txt"
IyMjIEVjbGlwc2UgV29ya3NwYWNlIFBhdGNoIDEuMAojUCBvcmcuZWNsaXBz ZS51aS53b3Jr
YmVuY2gKSW5kZXg6IEVjbGlwc2UgVUkvb3JnL2VjbGlwc2UvdWkvaW50ZXJu YWwva2V5cy9X
b3JrYmVuY2hLZXlib2FyZC5qYXZhCj09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KUkNTIGZpbGU6 IC9jdnNyb290
L2VjbGlwc2Uvb3JnLmVjbGlwc2UudWkud29ya2JlbmNoL0VjbGlwc2UgVUkv b3JnL2VjbGlw
c2UvdWkvaW50ZXJuYWwva2V5cy9Xb3JrYmVuY2hLZXlib2FyZC5qYXZhLHYK cmV0cmlldmlu
ZyByZXZpc2lvbiAxLjk3LjQuMQpkaWZmIC11IC1yMS45Ny40LjEgV29ya2Jl bmNoS2V5Ym9h
cmQuamF2YQotLS0gRWNsaXBzZSBVSS9vcmcvZWNsaXBzZS91aS9pbnRlcm5h bC9rZXlzL1dv
cmtiZW5jaEtleWJvYXJkLmphdmEJMzEgSnVsIDIwMDggMTc6MDM6MzUgLTAw MDAJMS45Ny40
LjEKKysrIEVjbGlwc2UgVUkvb3JnL2VjbGlwc2UvdWkvaW50ZXJuYWwva2V5 cy9Xb3JrYmVu
Y2hLZXlib2FyZC5qYXZhCTI5IEphbiAyMDA5IDE3OjQ4OjEzIC0wMDAwCkBA IC00NjksNyAr
NDY5LDkgQEAKIAkJfQogCiAJCXRyeSB7Ci0JCQloYW5kbGVyU2VydmljZS5l eGVjdXRlQ29t
bWFuZChwYXJhbWV0ZXJpemVkQ29tbWFuZCwgdHJpZ2dlcik7CisJCSAgaWYg KHdvcmtiZW5j
aC5nZXRBY3Rpdml0eVN1cHBvcnQoKS5nZXRBY3Rpdml0eU1hbmFnZXIoKS5n ZXRBY3Rpdml0
eShjb21tYW5kLmdldElkKCkpLmlzRW5hYmxlZCgpKSB7CisgICAgICAgIGhh bmRsZXJTZXJ2
aWNlLmV4ZWN1dGVDb21tYW5kKHBhcmFtZXRlcml6ZWRDb21tYW5kLCB0cmln Z2VyKTsKKyAg
ICAgIH0KIAkJfSBjYXRjaCAoZmluYWwgTm90RGVmaW5lZEV4Y2VwdGlvbiBl KSB7CiAJCQkv
LyBUaGUgY29tbWFuZCBpcyBub3QgZGVmaW5lZC4gRm9yd2FyZGVkIHRvIHRo ZSBJRXhlY3V0
aW9uTGlzdGVuZXIuCiAJCX0gY2F0Y2ggKGZpbmFsIE5vdEVuYWJsZWRFeGNl cHRpb24gZSkg
ewo=
--------------070405060508060707000609--
Previous Topic:Headless Build for Custom Builder
Next Topic:RCP dev - how to handle plugin.jars ?
Current Time: Mon Jul 21 23:44:55 EDT 2025
Powered by FUDForum. Page generated in 0.04391 seconds
