Home » Eclipse Projects » Eclipse Platform » Question about copy/paste behaviour on Linux
Question about copy/paste behaviour on Linux [message #330958] Tue, 19 August 2008 10:20 Go to next message
I am wondering if this is a known limitation (or maybe bug?) with
copy/paste behaviour on Linux...
On windows, I can copy a file from eclipse's project explorer, and then
paste it into an external app, such as Windows explorer. On Linux (I'm
using RHEL5), after I copy the file, I cannot paste it into the file
browser because the paste file action is always disabled (dragging a file
from eclipse to the file browser works however).
Andrew
Re: Question about copy/paste behaviour on Linux [message #330959 is a reply to message #330958] Tue, 19 August 2008 11:03 Go to previous message
I just tried this and confirmed this to be the case on Fedora 9 with
Eclipse 3.4 (using both the Project Exporer and Package Explorer).
Oddly drag/drop works fine.
You should file a bug about this. Assign it to Platform/UI.
Andrew Mak wrote:
> file from eclipse to the file browser works however).
> Andrew
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:what does "Referenced part does not exist yet" mean?
Next Topic:Add command handler to a control
Current Time: Mon Jul 21 22:24:06 EDT 2025
Powered by FUDForum. Page generated in 0.03149 seconds
