Home » Eclipse Projects » Eclipse Platform » Help regarding equinox p2
Help regarding equinox p2 [message #330949] Tue, 19 August 2008 07:52 Go to next message
Originally posted by: automatic.javalobby.org
I am facing a problem installing a feature using Equinox P2. Could someone please point me to any examples or documentation that would help solve the problem. Following are the steps taken to install a feature.
1.)We have developed a simple plugin using the HelloWorld template. Included the plugin in a feature. Both the plugin and feature folders are placed in the C:/sourceFolder.
2.) Generated the metadata using EclipseGenerator withe the following arguments.
-source C:/sourceFolder -metadataRepository
file:C:/repository/ -metadataRepositoryName "Sample Repository"
-artifactRepository file:C:/repository/ -artifactRepositoryName
"Sample Artifacts"
-publishArtifacts -publishArtifactRepository
4.) After the metadata is generated inthe C:/repository folder, tried
installing the featureby running the
org.eclipse.equinox.p2.director.app.application with the following
arguments.
-metadataRepository file:C:/repository/
This didn't throw any errors, but didn't install the feature either.
Also tried installing the feature using the Help > Software Updates>
Available Software. Added the C:/repository by selecting "Add Site"
button. Then selecting the "Install" menu in the context menu over
"Sample Feature". This too didn't work.
Please let us know if we are doing anything wrong here.
Re: Help regarding equinox p2 [message #330955 is a reply to message #330949] Tue, 19 August 2008 09:48 Go to previous message
reindheer wrote:
> "Sample Artifacts"
> arguments.
Re-directed
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Problem starting OSGI with framework.extension
Next Topic:what does "Referenced part does not exist yet" mean?
Current Time: Tue Nov 18 23:36:37 EST 2025
Powered by FUDForum. Page generated in 0.03702 seconds
