| Help icon in the NEW_WIZARD_SHORTLIST Contribution item [message #330946] |
Tue, 19 August 2008 03:38  |
I encountered some problems with the help icon in wizards. I have
created my own WizardDialog with the option setHelpAvailable(true).
Everything is fine. The wizard opens with the icon. For my coolbar and
the menu I use the NEW_WIZARD_SHORTLIST-ContributionItem and the wizards
are imported with the importWizard extension point
What happens is the following ...
first case: I start my RCP and use the contribution item to open a
wizard. No help icon is available.
second case: I open the wizard with my own action and my own
WizardDialog. Now I see the help icon. If I now want to open a wizard
with the contribution item I also see the icon. Can anybody tell me why?
I want all two case work in the same way. I want the help icon in the
ContributionItem too, even if I use th first case.
I have to say that I don't use the helpRefId in the newWizard extension
point. Has it something to do with it?
It is no bug, I know it, because if I open a wizard in the IDE, the
WizardDialog has the icon. I searched in the IDE code and extensions,
but found not the right answer.
Can you point me in the right direction?
Thank you,
Mark
FUDForum. Page generated in 0.04532 seconds
