Home » Eclipse Projects » Eclipse Platform » [Databinding] Trigger validation via my code
[Databinding] Trigger validation via my code [message #330941] Mon, 18 August 2008 15:53 Go to next message
can I trigger the validation for the UI fields via code?
I have a "copy" function which creates a copy of an existing object and
opens an editor which uses databinding for the model -> UI connectivity.
I have my own validator which checks the "name" field so that it does
not contain a name which is already in use.
But the check is only performed if the user enters something in the
field (SWT.Modify). As far as I know SWT.FocusOut or SWT.None would also
not help.
So how can I trigger the validation via my code without something
ridiculous like this:
// Trigger the validation
// Remember the old value
String text = nameText.getText();
// Put in nonsense
nameText.setText("Hello");
// And back to the old value
nameText.setText(text);
Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #330943 is a reply to message #330941] Mon, 18 August 2008 17:47 Go to previous messageGo to next message
Have you tried Binding.validateTargetToModel()?
Matthew
Lars Vogel wrote:
> not help.
> // Put in nonsense
> Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #330965 is a reply to message #330943] Tue, 19 August 2008 14:21 Go to previous messageGo to next message
Hi Matthew,
Thank you for the suggestion.
I don't think this works unless I did something wrong. Here is what I tried:
bindingContext = new DataBindingContext();
bindingContext.bindValue(SWTObservables.observeText(clientTe xt,
SWT.Modify), BeansObservables.observeValue(system, "client"),
update, null);
IObservableList bindings = bindingContext.getBindings();
for (Object object : bindings) {
if (object instanceof Binding) {
((Binding) object).validateTargetToModel();
Any further advice?
Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #330967 is a reply to message #330965] Tue, 19 August 2008 15:57 Go to previous messageGo to next message
Lars,
What are you using to display the validation status?
Matthew
Lars Vogel wrote:
> Hi Matthew,
> tried:
> "client"),
> update, null);
> Any further advice?
> Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #330984 is a reply to message #330967] Wed, 20 August 2008 09:54 Go to previous messageGo to next message
Matthew Hall wrote:
> Lars,
Hi Matthew,
AggregateValidationStatus, e.g.:
final IObservableValue validationStatus = new AggregateValidationStatus(
bindingContext.getBindings(),
AggregateValidationStatus.MAX_SEVERITY);
validationStatus.addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
IStatus status = (IStatus) validationStatus.getValue();
if (status.isOK()) {
form.setMessage("", IMessageProvider.NONE);
} else {
form
.setMessage(status.getMessage(),
IMessageProvider.ERROR);
Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #331001 is a reply to message #330984] Wed, 20 August 2008 18:05 Go to previous messageGo to next message
Lars,
Could you provide a standalone snippet demonstrating the problem? It's
hard to guess the source of your problem without seeing more code.
Matthew
Lars Vogel wrote:
> Matthew Hall wrote:
>> Lars,
> Hi Matthew,
> } else {
> form
> Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #331040 is a reply to message #331001] Thu, 21 August 2008 16:08 Go to previous messageGo to next message
Hi Matthew,
ok, I'll extract an example and post it as soon as possible.
Best regards, Lars
Matthew Hall wrote:
> Lars,
> Matthew
> Lars Vogel wrote:
>> Matthew Hall wrote:
>>> Lars,
>> Hi Matthew,
>> } else {
>> form
>> Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #331104 is a reply to message #331001] Mon, 25 August 2008 08:56 Go to previous messageGo to next message
Hi Matthew,
attached a small example which is a small modification of:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet004DataBindingContextErrorLabel.java?view =markup
Best regards, Lars
package org.eclipse.jface.examples.databinding.snippets;
import org.eclipse.core.databinding.AggregateValidationStatus;
import org.eclipse.core.databinding.Binding;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.UpdateValueStrategy;
import org.eclipse.core.databinding.beans.PojoObservables;
import org.eclipse.core.databinding.observable.ChangeEvent;
import org.eclipse.core.databinding.observable.IChangeListener;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.list.IObservableList ;
import org.eclipse.core.databinding.observable.value.IObservableVal ue;
import org.eclipse.core.databinding.validation.IValidator;
import org.eclipse.core.databinding.validation.ValidationStatus;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
* Snippet that displays how to bind the validation error of the
* {@link DataBindingContext} to a label. http://www.eclipse.org
* @since 3.2
public class Snippet004ModifiedDataBindingContext {
final Display display = new Display();
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
public void run() {
MyClass test = new MyClass();
test.setFirstName("Jim");
Shell shell = new Shell(display);
shell.setText("Data Binding Snippet 004 - Modified");
shell.setLayout(new GridLayout(2, false));
new Label(shell, SWT.NONE).setText("Enter 'Joe' to be valid:");
Text text = new Text(shell, SWT.BORDER);
new Label(shell, SWT.NONE).setText("Error:");
DataBindingContext dbc = new DataBindingContext();
// Bind the text to the value.
dbc.bindValue(SWTObservables.observeText(text, SWT.Modify),
PojoObservables.observeValue(test, "firstName"),
new UpdateValueStrategy()
.setAfterGetValidator(new FiveValidator()),
null);
dbc.getBindings(),
if (!status.isOK()) {
MessageDialog.openError(new Shell(display),
"Error", status.getMessage());
IObservableList bindings = dbc.getBindings();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* Validator that returns validation errors for any value other than 5.
* @since 3.2
private static class FiveValidator implements IValidator {
public IStatus validate(Object value) {
return ("Joe".equals(value)) ? Status.OK_STATUS : ValidationStatus
.error("the value was '" + value + "', not 'Joe'");
public static class MyClass {
private String firstName = "";
public void setFirstName(String firstName) {
this.firstName = firstName;
public String getFirstName() {
return firstName;
Re: [Databinding] Trigger validation via my code [message #331112 is a reply to message #331104] Mon, 25 August 2008 13:55 Go to previous messageGo to next message
--------------030100080007060207000603
Lars,
The change listener doesn't work because AggregateValidationStatus
computes the initial status (which is an error in this case) when it is
constructed. So there is no change event being fired (and thus no error
message being displayed) until the *next* change in the text field. A
few possible ways to fix this:
1) Construct the AggregateValidationStatus before creating any bindings,
and add the listener at that time. This works for this small example
but may be brittle in production use.
2) (Recommended) Use a value binding to bind the validation status to a
label. See the attached revised snippet to see what I mean.
Hope this helps,
Matthew
Lars Vogel wrote:
> Hi Matthew,
> Best regards, Lars
name="Snippet004ModifiedDataBindingContext.java"
Content-Disposition: inline;
filename="Snippet004ModifiedDataBindingContext.java"
cGFja2FnZSBvcmcuZWNsaXBzZS5qZmFjZS5leGFtcGxlcy5kYXRhYmluZGlu Zy5zbmlwcGV0
czsNCg0KaW1wb3J0IG9yZy5lY2xpcHNlLmNvcmUuZGF0YWJpbmRpbmcuQWdn cmVnYXRlVmFs
aWRhdGlvblN0YXR1czsNCmltcG9ydCBvcmcuZWNsaXBzZS5jb3JlLmRhdGFi aW5kaW5nLkRh
dGFCaW5kaW5nQ29udGV4dDsNCmltcG9ydCBvcmcuZWNsaXBzZS5jb3JlLmRh dGFiaW5kaW5n
LlVwZGF0ZVZhbHVlU3RyYXRlZ3k7DQppbXBvcnQgb3JnLmVjbGlwc2UuY29y ZS5kYXRhYmlu
ZGluZy5iZWFucy5Qb2pvT2JzZXJ2YWJsZXM7DQppbXBvcnQgb3JnLmVjbGlw c2UuY29yZS5k
YXRhYmluZGluZy5vYnNlcnZhYmxlLlJlYWxtOw0KaW1wb3J0IG9yZy5lY2xp cHNlLmNvcmUu
ZGF0YWJpbmRpbmcudmFsaWRhdGlvbi5JVmFsaWRhdG9yOw0KaW1wb3J0IG9y Zy5lY2xpcHNl
LmNvcmUuZGF0YWJpbmRpbmcudmFsaWRhdGlvbi5WYWxpZGF0aW9uU3RhdHVz Ow0KaW1wb3J0
IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5JU3RhdHVzOw0KaW1wb3J0IG9y Zy5lY2xpcHNl
LmNvcmUucnVudGltZS5TdGF0dXM7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZh Y2UuZGF0YWJp
bmRpbmcuc3d0LlNXVE9ic2VydmFibGVzOw0KaW1wb3J0IG9yZy5lY2xpcHNl LnN3dC5TV1Q7
DQppbXBvcnQgb3JnLmVjbGlwc2Uuc3d0LmxheW91dC5HcmlkRGF0YTsNCmlt cG9ydCBvcmcu
ZWNsaXBzZS5zd3QubGF5b3V0LkdyaWRMYXlvdXQ7DQppbXBvcnQgb3JnLmVj bGlwc2Uuc3d0
LndpZGdldHMuRGlzcGxheTsNCmltcG9ydCBvcmcuZWNsaXBzZS5zd3Qud2lk Z2V0cy5MYWJl
bDsNCmltcG9ydCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5TaGVsbDsNCmlt cG9ydCBvcmcu
ZWNsaXBzZS5zd3Qud2lkZ2V0cy5UZXh0Ow0KDQovKioNCiAqIFNuaXBwZXQg dGhhdCBkaXNw
bGF5cyBob3cgdG8gYmluZCB0aGUgdmFsaWRhdGlvbiBlcnJvciBvZiB0aGUg e0BsaW5rIERh
dGFCaW5kaW5nQ29udGV4dH0gdG8gYQ0KICogbGFiZWwuIGh0dHA6Ly93d3cu ZWNsaXBzZS5v
cmcNCiAqIA0KICogQHNpbmNlIDMuMg0KICovDQpwdWJsaWMgY2xhc3MgU25p cHBldDAwNE1v
ZGlmaWVkRGF0YUJpbmRpbmdDb250ZXh0IHsNCg0KICBwdWJsaWMgc3RhdGlj IHZvaWQgbWFp
biggU3RyaW5nW10gYXJncyApIHsNCiAgICBmaW5hbCBEaXNwbGF5IGRpc3Bs YXkgPSBuZXcg
RGlzcGxheSgpOw0KICAgIFJlYWxtLnJ1bldpdGhEZWZhdWx0KCBTV1RPYnNl cnZhYmxlcy5n
ZXRSZWFsbSggZGlzcGxheSApLCBuZXcgUnVubmFibGUoKSB7DQogICAgICBw dWJsaWMgdm9p
ZCBydW4oKSB7DQogICAgICAgIE15Q2xhc3MgdGVzdCA9IG5ldyBNeUNsYXNz KCk7DQogICAg
ICAgIHRlc3Quc2V0Rmlyc3ROYW1lKCAiSmltIiApOw0KICAgICAgICBTaGVs bCBzaGVsbCA9
IG5ldyBTaGVsbCggZGlzcGxheSApOw0KICAgICAgICBzaGVsbC5zZXRUZXh0 KCAiRGF0YSBC
aW5kaW5nIFNuaXBwZXQgMDA0IC0gTW9kaWZpZWQiICk7DQogICAgICAgIHNo ZWxsLnNldExh
eW91dCggbmV3IEdyaWRMYXlvdXQoIDIsIGZhbHNlICkgKTsNCg0KICAgICAg ICBuZXcgTGFi
ZWwoIHNoZWxsLCBTV1QuTk9ORSApLnNldFRleHQoICJFbnRlciAnSm9lJyB0 byBiZSB2YWxp
ZDoiICk7DQogICAgICAgIFRleHQgdGV4dCA9IG5ldyBUZXh0KCBzaGVsbCwg U1dULkJPUkRF
UiApOw0KICAgICAgICB0ZXh0LnNldExheW91dERhdGEoIG5ldyBHcmlkRGF0 YSggU1dULkZJ
TEwsIFNXVC5DRU5URVIsIHRydWUsIGZhbHNlICkgKTsNCg0KICAgICAgICBu ZXcgTGFiZWwo
IHNoZWxsLCBTV1QuTk9ORSApLnNldFRleHQoICJFcnJvcjoiICk7DQogICAg ICAgIExhYmVs
IGVycm9yID0gbmV3IExhYmVsKCBzaGVsbCwgU1dULldSQVAgKTsNCiAgICAg ICAgZXJyb3Iu
c2V0TGF5b3V0RGF0YSggbmV3IEdyaWREYXRhKCBTV1QuRklMTCwgU1dULkNF TlRFUiwgdHJ1
ZSwgZmFsc2UgKSApOw0KDQogICAgICAgIERhdGFCaW5kaW5nQ29udGV4dCBk YmMgPSBuZXcg
RGF0YUJpbmRpbmdDb250ZXh0KCk7DQoNCiAgICAgICAgLy8gQmluZCB0aGUg dGV4dCB0byB0
aGUgdmFsdWUuDQogICAgICAgIGRiYy5iaW5kVmFsdWUoIFNXVE9ic2VydmFi bGVzLm9ic2Vy
dmVUZXh0KCB0ZXh0LCBTV1QuTW9kaWZ5ICksIFBvam9PYnNlcnZhYmxlcw0K ICAgICAgICAg
ICAgLm9ic2VydmVWYWx1ZSggdGVzdCwgImZpcnN0TmFtZSIgKSwgbmV3IFVw ZGF0ZVZhbHVl
U3RyYXRlZ3koKQ0KICAgICAgICAgICAgLnNldEFmdGVyR2V0VmFsaWRhdG9y KCBuZXcgRml2
ZVZhbGlkYXRvcigpICksIG51bGwgKTsNCg0KICAgICAgICAvLyBCaW5kIHZh bGlkYXRpb24g
c3RhdHVzIHRvIGVycm9yIGxhYmVsDQogICAgICAgIGRiYy5iaW5kVmFsdWUo IFNXVE9ic2Vy
dmFibGVzLm9ic2VydmVUZXh0KCBlcnJvciApLCBuZXcgQWdncmVnYXRlVmFs aWRhdGlvblN0
YXR1cyggZGJjDQogICAgICAgICAgICAuZ2V0QmluZGluZ3MoKSwgQWdncmVn YXRlVmFsaWRh
dGlvblN0YXR1cy5NQVhfU0VWRVJJVFkgKSwgbnVsbCwgbnVsbCApOw0KDQog ICAgICAgIHNo
ZWxsLnBhY2soKTsNCiAgICAgICAgc2hlbGwub3BlbigpOw0KICAgICAgICB3 aGlsZSAoICFz
aGVsbC5pc0Rpc3Bvc2VkKCkgKSB7DQogICAgICAgICAgaWYgKCAhZGlzcGxh eS5yZWFkQW5k
RGlzcGF0Y2goKSApDQogICAgICAgICAgICBkaXNwbGF5LnNsZWVwKCk7DQog ICAgICAgIH0N
CiAgICAgIH0NCiAgICB9ICk7DQogICAgZGlzcGxheS5kaXNwb3NlKCk7DQog IH0NCg0KICAv
KioNCiAgICogVmFsaWRhdG9yIHRoYXQgcmV0dXJucyB2YWxpZGF0aW9uIGVy cm9ycyBmb3Ig
YW55IHZhbHVlIG90aGVyIHRoYW4gNS4NCiAgICogDQogICAqIEBzaW5jZSAz LjINCiAgICov
DQogIHByaXZhdGUgc3RhdGljIGNsYXNzIEZpdmVWYWxpZGF0b3IgaW1wbGVt ZW50cyBJVmFs
aWRhdG9yIHsNCiAgICBwdWJsaWMgSVN0YXR1cyB2YWxpZGF0ZSggT2JqZWN0 IHZhbHVlICkg
ew0KICAgICAgcmV0dXJuICggIkpvZSIuZXF1YWxzKCB2YWx1ZSApICkgPyBT dGF0dXMuT0tf
U1RBVFVTIDogVmFsaWRhdGlvblN0YXR1cw0KICAgICAgICAgIC5lcnJvcigg InRoZSB2YWx1
ZSB3YXMgJyIgKyB2YWx1ZSArICInLCBub3QgJ0pvZSciICk7DQogICAgfQ0K ICB9DQoNCiAg
cHVibGljIHN0YXRpYyBjbGFzcyBNeUNsYXNzIHsNCiAgICBwcml2YXRlIFN0 cmluZyBmaXJz
dE5hbWUgPSAiIjsNCg0KICAgIHB1YmxpYyB2b2lkIHNldEZpcnN0TmFtZSgg U3RyaW5nIGZp
cnN0TmFtZSApIHsNCiAgICAgIHRoaXMuZmlyc3ROYW1lID0gZmlyc3ROYW1l Ow0KICAgIH0N
Cg0KICAgIHB1YmxpYyBTdHJpbmcgZ2V0Rmlyc3ROYW1lKCkgew0KICAgICAg cmV0dXJuIGZp
cnN0TmFtZTsNCiAgICB9DQoNCiAgfQ0KfQ==
--------------030100080007060207000603--
Re: [Databinding] Trigger validation via my code [message #331113 is a reply to message #331112] Mon, 25 August 2008 17:00 Go to previous messageGo to next message
Hi Matthew,
I'm using Eclipse forms and I'm using the message manager. Binding the
validation a label would be a step back. Also the early binding doesn't
work for me as in my real example I'm providing the data to the
composite after creating the UI.
So there is really no other way to trigger the validation then this:
Matthew Hall wrote:
> Lars,
> Hope this helps,
> Matthew
> Lars Vogel wrote:
>> Hi Matthew,
>> Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #331114 is a reply to message #331113] Mon, 25 August 2008 17:02 Go to previous messageGo to next message
Sorry got send during writing it.
So there is no other way then triggering the validation other then my
initial example?
// Put in nonsense
Lars Vogel wrote:
> Hi Matthew,
> Matthew Hall wrote:
>> Lars,
>> is constructed. So there is no change event being fired (and thus no
>> error message being displayed) until the *next* change in the text
>> field. A few possible ways to fix this:
>> bindings, and add the listener at that time. This works for this
>> small example but may be brittle in production use.
>> a label. See the attached revised snippet to see what I mean.
>> Hope this helps,
>> Matthew
>> Lars Vogel wrote:
>>> Hi Matthew,
>>> Best regards, Lars
Lars Vogel
http://www.vogella.de/eclipse.html - Tutorials about Eclipse
http://www.vogella.de/articles/RichClientPlatform/article.ht ml - Eclipse
RCP Tutorial
Re: [Databinding] Trigger validation via my code [message #331115 is a reply to message #331113] Mon, 25 August 2008 19:00 Go to previous messageGo to next message
Lars,
Try this:
IObservableValue statusObservable = new WritableValue();
statusObservable.addChangeListener(new IChangeListener() {
// your change listener code
dbc.bindValue(statusObservable, new AggregateValidationStatus(
dbc.getBindings(), AggregateValidationStatus.MAX_SEVERITY),
null, null);
Matthew
Lars Vogel wrote:
> Hi Matthew,
> Matthew Hall wrote:
>> Lars,
>> Hope this helps,
>> Matthew
>> Lars Vogel wrote:
>>> Hi Matthew,
>>> Best regards, Lars
Re: [Databinding] Trigger validation via my code [message #331116 is a reply to message #331115] Mon, 25 August 2008 18:33 Go to previous messageGo to next message
Hi Matthew,
cool, this works.
Thank you very much.
Best regards, Lars
Matthew Hall wrote:
> Lars,
> Try this:
> null, null);
> Matthew
> Lars Vogel wrote:
>> Hi Matthew,
>> doesn't work for me as in my real example I'm providing the data to
>> the composite after creating the UI.
>> Matthew Hall wrote:
>>> Lars,
>>> Hope this helps,
>>> Matthew
>>> Lars Vogel wrote:
>>>> Hi Matthew,
>>>> Best regards, Lars
Lars Vogel
RCP Tutorial
Re: [Databinding] Trigger validation via my code [message #331118 is a reply to message #331116] Mon, 25 August 2008 21:36 Go to previous message
Sweet!
Previous Topic:Activities - Should It Work With A launchDelegates Conribution?
Next Topic:Changing Marker Hilight Color
Current Time: Tue Jul 22 11:11:26 EDT 2025
Powered by FUDForum. Page generated in 0.05235 seconds
