Home » Eclipse Projects » Eclipse Platform » Saving the state of toggle actions
Saving the state of toggle actions [message #330904] Fri, 15 August 2008 19:21 Go to next message
Hi All,
I have a toggle action in my plug-in and i would like it to persist
between start-ups of Eclipse. I actually want to do exactly what Eclipse
has for Build Automatically.
You can turn it on and next time you start eclipse it is turned on. I know
Eclipse holds a field about this in the Preferences Page
(IDEWorkspacePreferencePage.java) but I can not figure out how to tell
change the initial state of my action.
Nikola
Re: Saving the state of toggle actions [message #330937 is a reply to message #330904] Mon, 18 August 2008 10:45 Go to previous message
Actions? Or commands? Even with actions, I don't believe the state of
a toggle or radio contribution is saved and then restored.
I believe that state tends to be part of the plugin's model, but of
course access the plugin's model usually means starting the plugin,
which will eventually load all of the visible UI elements and action
delegates/command handlers.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:eclipse key bindings
Next Topic:JFace ToolTip Accessibility
Current Time: Thu Jul 17 22:16:59 EDT 2025
Powered by FUDForum. Page generated in 0.08469 seconds
