Home » Language IDEs » PHP Development Tools (PDT) » Xdebug: files with same name
Xdebug: files with same name [message #2869] Sat, 03 March 2007 07:51 Go to next message
Originally posted by: johan.bobsworld.be
Hello
In my project I have an index.php in the root directory and an index.php
in a subfolder named test. When I set a breakpoint in the test/index.php
and run the script, xdebug takes me to the debug screen of eclipse, but
the sourcefile of the index.php in the root of the project is shown
instead of the test/index.php.
Have the same problem with classes that have the same name, but are in
another folder.
Is this a known bug? Or is something wrong with the configuration of my
project?
Thanks in advance.
Johan Vandeweerd
Re: Xdebug: files with same name [message #2924 is a reply to message #2869] Mon, 05 March 2007 06:26 Go to previous messageGo to next message
A quick test works for me if I have an index.php and a test/index.php an I
do a web launch for index.php I enter that version and if I launch on /test/index.php
I use that copy. In my case I am not using the path mapper version and my apache
document root is pointing to my workspace.
Are you using the path mapper version ?
where are you pointing your apache document root to ?
Dave Kelsey
Johan Vandeweerd wrote:
> Hello
> another folder.
> project?
> Thanks in advance.
> Johan Vandeweerd
Re: Xdebug: files with same name [message #2942 is a reply to message #2924] Mon, 05 March 2007 16:00 Go to previous messageGo to next message
Yes, I'm using path mapper. I installed PDT 0.7 20070130 with xdebug
0.1.3.logik
My desktop pc is windows xp and my apache server is on debian. The
document root is shared with samba.
Doc root is in /var/www and shared and mounted as j: drive.
I've mapped j:/someproject to /var/www/someproject. Both with forward
slash and without a slash at the end.
The rest of debugging works like a charm (thanks for that btw ;-).
Johan Vandeweerd
> /test/index.php
> my apache
> Dave Kelsey
>> Hello
>> index.php in a subfolder named test. When I set a breakpoint in the
>> test/index.php and run the script, xdebug takes me to the debug screen
>> of eclipse, but the sourcefile of the index.php in the root of the
>> project is shown instead of the test/index.php.
>> another folder.
>> my project?
>> Thanks in advance.
>> Johan Vandeweerd
Re: Xdebug: files with same name [message #2958 is a reply to message #2942] Tue, 06 March 2007 05:10 Go to previous messageGo to next message
Hi Johan, It is probably an issue with the path mapper version. Hopefully the
owner of that code can look into it. Sorry I can't help further.
Just out of curiosity, how many different mappings do you use on a single launch ?
Dave Kelsey
> Hi
> 0.1.3.logik
> Regards
> Johan Vandeweerd
>> an I
>> /test/index.php
>> my apache
>> Dave Kelsey
>>> Hello
>>> screen of eclipse, but the sourcefile of the index.php in the root of
>>> the project is shown instead of the test/index.php.
>>> in another folder.
>>> my project?
>>> Thanks in advance.
>>> Johan Vandeweerd
Re: Xdebug: files with same name [message #2975 is a reply to message #2958] Tue, 06 March 2007 09:13 Go to previous messageGo to next message
Hello
Only one. Currently I'm only working on one project and the root folder
of that project is mapped.
Are you planning to implement a workaround/fix for the mapping problem
or is it going to stay with the hack (no offence, I'm very happy with
the path mapper)?
Johan Vandeweerd
> Hopefully the
> single launch ?
> Dave Kelsey
>> Hi
>> 0.1.3.logik
>> Regards
>> Johan Vandeweerd
>>> an I
>>> /test/index.php
>>> and my apache
>>> Dave Kelsey
>>>> Hello
>>>> of the project is shown instead of the test/index.php.
>>>> in another folder.
>>>> my project?
>>>> Thanks in advance.
>>>> Johan Vandeweerd
Re: Xdebug: files with same name [message #3009 is a reply to message #2975] Tue, 06 March 2007 10:29 Go to previous messageGo to next message
No I won't be trying to fix this issue with the path mapper version. You may
want to contact the author of that code if you need a fix soon.
I have been looking at providing an extension point which will allow a path
mapper to be plugged into the XDebug support, and I will have a sample mapper
which would allow you to define the location of your apache document root
and will map your project to the apache document root. Then people can create
their own mappers which are more complex.
I would hope to make this version available soon after the 0.7 version of
PDT is available.
Dave Kelsey
> Hello
> the path mapper)?
> Regards
> Johan Vandeweerd
>> Hopefully the
>> single launch ?
>> Dave Kelsey
>>> Hi
>>> 0.1.3.logik
>>> Regards
>>> Johan Vandeweerd
>>>> test/index.php an I
>>>> on /test/index.php
>>>> and my apache
>>>> Dave Kelsey
>>>>> Hello
>>>>> in another folder.
>>>>> of my project?
>>>>> Thanks in advance.
>>>>> Johan Vandeweerd
Re: Xdebug: files with same name [message #9079 is a reply to message #2869] Fri, 23 March 2007 09:25 Go to previous messageGo to next message
Originally posted by: dominic.clifton.gr-tech.net
There is actually a workaround for this until a proper solution is
implemented:
* Start an xdebug session
* Switch to the "PHP Debug" perspective
* In The "Debug" view, right click the "PHP Web Script with XDebug" (or
whatever type of debugger you're using) and from the context menu that
appears select "Edit source lookup..".
* Tick "Search for duplicate files on the path"
Now whenever you hit a breakpoint in a file that has the same name as
another file you'll be prompted to select the right file.
Not ideal, but it does appear to work ok for me, hope this helps.
Dom
Re: Xdebug: files with same name [message #11997 is a reply to message #2869] Tue, 03 April 2007 12:14 Go to previous messageGo to next message
Hi, I am the author of the Path Mapper, and I have been away on the
holiday.
Yeah it is know issue (if you can call it that). I think the issue was
that eclipse opens the file by the name only, so it opens the first file
of that name it sees.
What I have done is adjusted the source lookups, so that the folder I want
overrides the default one.
I will try to see if something can be done to fix the issue (from what I
remember it wasn't an easy fix, or possible, otherwise I would have done
it).
Re: Xdebug: files with same name [message #12036 is a reply to message #11997] Wed, 04 April 2007 04:20 Go to previous message
Max, the new version of XDebug will have an extension point which will
sort out this issue for you. You will need to port your port mapper to
the interface but that means you want need to patch the base code.
I am waiting for the next stable release from pdt and I will port the code
to that version and release it
Dave Kelsey
> holiday.
> want overrides the default one.
> it).
Previous Topic:Strange auto formatting bug
Next Topic:Soething for a begginer
Current Time: Fri Nov 21 00:56:46 EST 2025
Powered by FUDForum. Page generated in 0.05795 seconds
