Home » Eclipse Projects » Eclipse Platform » Problem with eclipse head-less build
Problem with eclipse head-less build [message #330802] Wed, 13 August 2008 13:24 Go to next message
Hello All,
I am trying to build a feature using eclipse head-less build system. The
build works fine, but it is generating folders with plugin binaries in it,
but I want it to create plug-in jars. I noticed that building a product is
creating plug-in jars. Can any one help me in getting a solution to work
with...
thanks,
Sridhar
Re: Problem with eclipse head-less build [message #330808 is a reply to message #330802] Wed, 13 August 2008 16:30 Go to previous message
The shape of the plug-ins are controlled by the containing feature.
In the feature editor, look on the Plug-ins tab, select an included
plug-in and uncheck "Unpack the plug-in archive after the installation".
In the feature.xml itself, this corresponds to the unpack attribute:
<plugin id="org.eclipse.equinox.launcher"
unpack="false"/>
If not specified, the default value for the unpack attribute is true,
which leads to folder shaped plug-ins. unpack="false" means keep the
plug-ins as jars.
-Andrew
Sri_know wrote:
> Hello All,
> with...
> thanks,
> Sridhar
Previous Topic:Generating a custom project structure
Next Topic:deserialization ClassNotFound when class is supplied through extension-point
Current Time: Thu Nov 13 18:39:24 EST 2025
Powered by FUDForum. Page generated in 0.03629 seconds
