Home » Eclipse Projects » Eclipse Platform » Open File in Editor
Open File in Editor [message #330786] Wed, 13 August 2008 09:39 Go to next message
How do I write code that will open a java file in the Java Editor?
I thought to do IEditorPart
editor=PlatformUI.getWorkbench().getActiveWorkbenchWindow(). getActivePage().openEditor(input,
editorId), but I have two problems:
1)I'm not sure how to get an IEditorInput for a particular file
2) I don't know what the ID of the default java editor is
Re: Open File in Editor [message #330797 is a reply to message #330786] Wed, 13 August 2008 11:19 Go to previous messageGo to next message
Use org.eclipse.jdt.ui.JavaUI.openInEditor(IJavaElement)
Dani
Re: Open File in Editor [message #330835 is a reply to message #330786] Thu, 14 August 2008 09:24 Go to previous messageGo to next message
If you have an IFile, you can use org.eclipse.ui.ide.IDE.openEditor()
instead.
Hope this helps,
Eric
Re: Open File in Editor [message #330865 is a reply to message #330786] Thu, 14 August 2008 13:59 Go to previous messageGo to next message
The following code should help for files outside the workbench otherwise
use IFile
IFileStore fileLocation =
EFS.getLocalFileSystem().getStore(new URI("file://" + fileSelected));
FileStoreEditorInput fileStoreEditorInput = new
FileStoreEditorInput(xmlLocation);
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
page.openEditor((IEditorInput)fileStoreEditorInput,
<EDITOR_ID>);
I believe the ID is
org.eclipse.jdt.ui.CompilationUnitEditor
You can get the values from IEditorDescriptor api.
Prasad
Re: Open File in Editor [message #330867 is a reply to message #330865] Thu, 14 August 2008 14:01 Go to previous message
> use IFile
> <EDITOR_ID>);
oops the correct code is
EFS.getLocalFileSystem().getStore(new URI("file://" + filePathInOS));
FileStoreEditorInput(fileLocation);
<EDITOR_ID>, true);
> I believe the ID is
> Prasad
Previous Topic:Are enabled activities persisted?
Next Topic:upgrading Eclipse platform?
Current Time: Mon Jul 21 22:02:06 EDT 2025
Powered by FUDForum. Page generated in 0.27805 seconds
