Home » Eclipse Projects » Eclipse Platform » A different problem running Eclipse Ganymede on Ubuntu Gutsy Gibbon
A different problem running Eclipse Ganymede on Ubuntu Gutsy Gibbon [message #330739] Tue, 12 August 2008 10:08 Go to next message
Originally posted by: fogartyrb.gmail.com
I too am having problems running Eclipse Ganymede on Ubuntu Gutsy Gibbon.
I don't have gcj installed. I have tried both
jdk1.5.0_15 and jdk1.6.0_10. Specifically builds:
java version "1.5.0_15"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_15-b04)
Java HotSpot(TM) Server VM (build 1.5.0_15-b04, mixed mode)
and
java version "1.6.0_10-rc"
Java(TM) SE Runtime Environment (build 1.6.0_10-rc-b28)
Java HotSpot(TM) Server VM (build 11.0-b15, mixed mode)
When I launch eclipse (with or without the -vm option). I get the
following in workspace/.metadata/.log:
!SESSION 2008-08-12 08:39:23.072
eclipse.buildId=I20080617-2000
java.version=1.5.0_15
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ui 4 0 2008-08-12 08:39:27.073
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.jface.resource.FileImageDescriptor.getFilePath(F ileImageDescriptor.java:219)
org.eclipse.jface.resource.FileImageDescriptor.createImage(F ileImageDescriptor.java:172)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:227)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:205)
at org.eclipse.jface.action.StatusLine.<init>(StatusLine.java:286)
org.eclipse.jface.action.StatusLineManager.createControl(Sta tusLineManager.java:99)
org.eclipse.ui.presentations.AbstractPresentationFactory.cre ateStatusLineControl(AbstractPresentationFactory.java:125)
org.eclipse.ui.internal.WorkbenchWindow.createStatusLine(Wor kbenchWindow.java:3800)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:1082)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:625)
org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:268)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:998)
at org.eclipse.jface.window.Window.create(Window.java:431)
org.eclipse.ui.internal.Workbench$20.runWithException(Workbe nch.java:1014)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
If anyone has any ideas I would be very appreciated. Note, I had it
running but then I did install KDE stuff and some extra gtk and qt stuff
to get the latest Kvpnc running and Konqueror.
Thank you,
Ryan Fogarty
Oops that was on Ubuntu Hardy Heron not Gutsy Gibbon [message #330745 is a reply to message #330739] Tue, 12 August 2008 10:12 Go to previous messageGo to next message
Please excuse mind-slip that is Ubuntu Hardy Heron.
Thanks again,
Ryan
Re: A different problem running Eclipse Ganymede on Ubuntu Gutsy Gibbon [message #550078 is a reply to message #330739] Thu, 29 July 2010 01:12 Go to previous message
I have the same exception message trying to open a xhmtl page with the JBoss Tool HTML editor.
My environment is Eclipse Ganymede with JBoss Tools 3.0.2 GA in Windows XP.
Have you found some solution to your problem ?
Any information is appreciated.
Previous Topic:Ignoring Eclipse build/builders when modifying project structure/classpath
Next Topic:history view doesn't display items
Current Time: Thu Nov 13 20:31:56 EST 2025
Powered by FUDForum. Page generated in 0.03944 seconds
