Home » Eclipse Projects » Eclipse Platform » Problems while running Eclipse 3.3.2 on Ubuntu 8.04
Problems while running Eclipse 3.3.2 on Ubuntu 8.04 [message #330732] Tue, 12 August 2008 07:49 Go to next message
Dear All,
I am having following problem while running Eclipse 3.3.2 on Ubuntu 8.04
java -version shows
java version "1.6.0_06"
Java(TM) SE Runtime Environment (build 1.6.0_06-b02)
Java HotSpot(TM) 64-Bit Server VM (build 10.0-b22, mixed mode)
then, I downloaded Eclipse
eclipse-SDK-3.3.2-linux-gtk.tar.gz from eclipse.org
and extracted in my home/opt/
while running eclipse i am getting ...
JVM terminated. Exit code=13
/usr/bin/java
-Xms40m
-Xmx256m
-jar
/home/touchpoint/opt/eclipse/plugins/org.eclipse.equinox.lau ncher_1.0.1.R33x_v20080118.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /home/touchpoint/opt/eclipse/eclipse
-name Eclipse
--launcher.library
/home/touchpoint/opt/eclipse/plugins/org.eclipse.equinox.lau ncher.gtk.linux.x86_1.0.3.R33x_v20080118/eclipse_1023.so
-startup
-exitdata b800e
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar
How can I fix this?
With Thanks & Regards,
-arun
Re: Problems while running Eclipse 3.3.2 on Ubuntu 8.04 [message #330748 is a reply to message #330732] Tue, 12 August 2008 10:30 Go to previous messageGo to next message
The exit code 13 implies that Java was started and we at least tried to
start the OSGi framework. Try looking in the configuration directory
for a log file that would give more details about what went wrong.
-Andrew
Arunagiri K wrote:
> Dear All,
> java -version shows
> /usr/bin/java
> -Xms40m
> -Xmx256m
> -jar
> -os linux
> -ws gtk
> -arch x86
> -showsplash
> -name Eclipse
> --launcher.library
> -startup
> -exitdata b800e
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx256m
> -jar
> How can I fix this?
> -arun
Re: Problems while running Eclipse 3.3.2 on Ubuntu 8.04 [message #330750 is a reply to message #330732] Tue, 12 August 2008 11:21 Go to previous messageGo to next message
"Arunagiri K" <arungi@gmail.com> wrote in message
news:b611ac73110800c44faac04918bca992$1@www.eclipse.org...
> Dear All,
> java -version shows
> eclipse-SDK-3.3.2-linux-gtk.tar.gz from eclipse.org [...]
I think maybe you are trying to run a 32-bit Eclipse on a 64-bit JVM?
Re: Problems while running Eclipse 3.3.2 on Ubuntu 8.04 [message #330762 is a reply to message #330750] Tue, 12 August 2008 12:09 Go to previous message
Thanks, u r correct,
I am running eclipse-SDK-3.3.2-linux-gtk
instead of eclipse-SDK-3.3.2-linux-gtk-x86_64
Now it's solved.
Previous Topic:Managing branches and tags in cvs
Next Topic:java heap | Out of memory | jobs api
Current Time: Fri Jul 25 22:04:38 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
