Home » Eclipse Projects » Eclipse Platform » Unzipping eclipse download requires password?!?
Unzipping eclipse download requires password?!? [message #330686] Fri, 08 August 2008 08:57 Go to next message
I downloaded the Eclipse Modeling Tools (includes Incubating components)
variant of eclipse from http://www.eclipse.org/downloads/packages/.
This yields a file eclipse-modeling-ganymede-incubation-win32.zip,
which - when trying to unzip - after a while asks for a password for
several files. IMHO there shouldn't be any pwds required to unzip an
eclipse distro. But maybe that error msg. was an error itself (this was
using Win XP's built-in zip extractor), so I tried to unzip the file
using WinZip and here I get a "The filename is too long. Unable to
extract ....".
Net-result: that distro - at least on Windoze - seems unusable. Where do
I report such a mishap?
Michael
Re: Unzipping eclipse download requires password?!? [message #330689 is a reply to message #330686] Fri, 08 August 2008 09:24 Go to previous messageGo to next message
> This yields a file eclipse-modeling-ganymede-incubation-win32.zip, which
> - when trying to unzip - after a while asks for a password for several
> files. IMHO there shouldn't be any pwds required to unzip an eclipse
> distro. But maybe that error msg. was an error itself (this was using
> Win XP's built-in zip extractor), so I tried to unzip the file using
> WinZip and here I get a "The filename is too long. Unable to extract ....".
This wiki page, http://wiki.eclipse.org/SDK_Known_Issues#Windows_issues
explains the problems with unzipping on Windows. There is a link to that
page on the main packages downloads page, but not for some reason on the
page you were looking at, http://www.eclipse.org/downloads/packages/
I've re-opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=169776 to
(hopefully) correct that.
Hope this helps,
Eric
Re: Unzipping eclipse download requires password?!? [message #330735 is a reply to message #330689] Tue, 12 August 2008 08:48 Go to previous messageGo to next message
Eric Rizzo wrote:
> This wiki page,
> http://wiki.eclipse.org/SDK_Known_Issues#Windows_issues explains the
> problems with unzipping on Windows. There is a link to that page on
> the main packages downloads page, but not for some reason on the page
> you were looking at, http://www.eclipse.org/downloads/packages/ I've
> Hope this helps,
> Eric
Thanks - it did help. Except for the path issue.
I have several eclipse versions running and have thus put them into
directories like:
C:\eclipse_3.3\<eclipse-as-unzipped>
C:\eclipse_3.4\<eclipse-as-unzipped>
etc.
Things are becoming a bit cumbersome, if one can't even add such a short
prefix any more. Developers shouldn't use that limit up to the last
character, but allow for at least 20 or so characters left. Or else
making a backup of an eclipse folder to directories that contain e.g. a
date as part of the filename becomes impossible.
IMHO the eclipse projects should start thinking about a different naming
scheme anyway. I mean: combining full package-names, version and build
numbers up to 4 levels deep and ranging in the hundreds (like
v1.2.30.400), dates or sometimes timesstamps with minutes and even
seconds plus sometimes even additional hashes (or whatever that
gobledygook at the end of some filename is) into filenames and then
wrapping such files again in directories (maybe even nested several
times) with similar convoluted names at some points simply overdoes it.
While such a limit is certainly annoying and not exactly "adequate for a
modern OS" any more, to be honest - I think it's not the most stupid
thing that Windows puts at least *some* limit to this kind of nonsense!
Not far the day, I guess, when we will have to define different drives
(C:\eclipse, D:\eclipse\, ...) to be able install different eclipse
versions. ||-(
Michael
Re: Unzipping eclipse download requires password?!? [message #330752 is a reply to message #330735] Tue, 12 August 2008 11:40 Go to previous messageGo to next message
> versions. ||-(
You know, you can always install Linux, I hear the cool kids use that
these days ;)
~ Chris
Re: Unzipping eclipse download requires password?!? [message #330758 is a reply to message #330735] Tue, 12 August 2008 12:04 Go to previous messageGo to next message
> Eric Rizzo wrote:
>> This wiki page,
>> Hope this helps,
>> Eric
> directories like:
> etc.
I use a structure like this on Windoze XP and 2000 without any problems:
D:\
Java\
Eclipse\
3.3\
3.4\
workspaces\
Also, see this bug report for some debate about what to do with this
issue in general:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166597
> versions. ||-(
> Michael
Re: Unzipping eclipse download requires password?!? [message #330876 is a reply to message #330735] Thu, 14 August 2008 17:35 Go to previous messageGo to next message
The rant is well taken, and we have been working towards making those
paths shorter. The Eclipse SDK for example now has a longest path
length of 121, as opposed to 169 in the 3.3.2 release. This is still
long, but on a system with a 255 character limit it should allow for
another 134 characters of prefix to be safely added, which is not bad.
There is a bug report about reducing the size of the "gobledygook", but
it is actually quite a difficult problem
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=175714).
However, the real problem you are seeing is because the EMF project has
not switched over to using source bundles (see bug 14872 for a
description of source bundles). They still use source features, which
had the property of creating nested directories with qualifiers and
timestamps and gobledygook. This is the reason you are hitting the path
limit with such a small prefix.
Re: Unzipping eclipse download requires password?!? [message #330878 is a reply to message #330876] Thu, 14 August 2008 18:25 Go to previous messageGo to next message
John,
It's good to know EMF is the real problem. :-P
I think https://bugs.eclipse.org/bugs/show_bug.cgi?id=14872 is a stray
pointer though. Is there something more specific I should look at? I
wonder if Nick is aware that there is a new improved way to do
something? I, added him to the CC list, though he's on vacation right
now.
I'm not aware of any enhancement requests to change how source plugins
are packaged. I suppose that's common knowledge, but it's the first
I've heard about it...
>> naming scheme anyway. I mean: combining full package-names, version
>> and build numbers up to 4 levels deep and ranging in the hundreds
>> (like v1.2.30.400), dates or sometimes timesstamps with minutes and
>> even seconds plus sometimes even additional hashes (or whatever that
> but it is actually quite a difficult problem
> has not switched over to using source bundles (see bug 14872 for a
> path limit with such a small prefix.
Re: Unzipping eclipse download requires password?!? [message #330882 is a reply to message #330878] Thu, 14 August 2008 19:51 Go to previous messageGo to next message
I've downloaded and unpacked the Ganymede modeling package on a few
machines now and there's only one file that WinZip won't unpack into
c:\eclipse34modeling\ on XP for me.
" eclipse\plugins\org.eclipse.uml2.diagram.examples.clazz_0.8. 0.v200806112132\diagram\07-02-03\09
Composite Structures\Figure 9.11 - The internal structure of the
Observer collaboration shown inside the collaboration
icon.umlcompositesitestructures_diagram"
The things I use seem to work fine without it.
Steve
Ed Merks wrote:
> John,
> something? I, added him to the CC list, though he's on vacation right now.
Re: Unzipping eclipse download requires password?!? [message #330884 is a reply to message #330882] Thu, 14 August 2008 20:53 Go to previous messageGo to next message
Steve,
That sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=240632.
> Steve
> Ed Merks wrote:
>> John,
>> stray pointer though. Is there something more specific I should look
>> at? I wonder if Nick is aware that there is a new improved way to do
>> right now.
>> plugins are packaged. I suppose that's common knowledge, but it's
>> the first I've heard about it...
>>>> that gobledygook at the end of some filename is) into filenames and
>>>> then wrapping such files again in directories (maybe even nested
>>>> several times) with similar convoluted names at some points simply
>>>> overdoes it.
>>> those paths shorter. The Eclipse SDK for example now has a longest
>>> path length of 121, as opposed to 169 in the 3.3.2 release. This is
>>> still long, but on a system with a 255 character limit it should
>>> allow for another 134 characters of prefix to be safely added, which
>>> is not bad. There is a bug report about reducing the size of the
>>> "gobledygook", but it is actually quite a difficult problem
>>> which had the property of creating nested directories with
>>> qualifiers and timestamps and gobledygook. This is the reason you
>>> are hitting the path limit with such a small prefix.
Re: Unzipping eclipse download requires password?!? [message #330886 is a reply to message #330884] Fri, 15 August 2008 01:29 Go to previous messageGo to next message
Ed Merks wrote:
> Steve,
And another validation of Rule 34 -- "... it is already posted on the
Internet". Stripping spaces and renaming files is inside my skill set
but I'm not sure how to contribute to a fix ;)
java ? sleep || perl : chooseTwo();
Re: Unzipping eclipse download requires password?!? [message #330996 is a reply to message #330878] Wed, 20 August 2008 14:19 Go to previous message
Sorry, the correct pointer is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148782. A better reference
would be http://wiki.eclipse.org/PDEBuild/Individual_Source_Bundles.
I'll open a bug against EMF.
Previous Topic:Calculating plugin classpath for a launch configuration
Next Topic:[Databinding] Editor (isDirty), PojoObservable and ChangeListener on target to
Current Time: Wed Nov 19 15:54:54 EST 2025
Powered by FUDForum. Page generated in 0.05092 seconds
