| initializationError0 When Running JUnits Through Eclipse [message #330668] |
Thu, 07 August 2008 16:28 |
Originally posted by: ian.dees.gmail.com
Hi everyone,
On some of my JUnits that I run through Eclipse's JUnit interface
(alt-shift-x + t), I get an "initializationError0" as the only test, with
a Failure Trace of:
java.lang.VerifyError: (class: com/xx/yy/zzTest, method: unmarshall
signature: ([B[B)Lcom/xx/yy/zz;) Incompatible argument to function
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.getConstructor(Class.java:1657)
at junit.framework.TestSuite.getTestConstructor(TestSuite.java: 177)
at junit.framework.TestSuite.<init>(TestSuite.java:59)
org.junit.internal.runners.OldTestClassRunner.<init>(OldTestClassRunner.java:23)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
org.junit.internal.requests.ClassRequest.getRunner(ClassRequ est.java:27)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init >(JUnit4TestReference.java:28)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassRefere nce. <init>(JUnit4TestClassReference.java:24)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.crea teTest(JUnit4TestLoader.java:40)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.load Tests(JUnit4TestLoader.java:30)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
These tests are working on others' machines and on the build server, so
I'm convinced that it is my copy of Eclipse having the issue.
I'm running Version: 3.4.0, Build id: I20080617-2000.
Please forgive me if this is not the right place to ask a question, the
eclipse website is pretty unclear about where to go for a question like
this.
-Ian
FUDForum. Page generated in 0.03496 seconds
