Home » Eclipse Projects » Eclipse Platform » Some very very strange thing about the open action in the CNF?
Some very very strange thing about the open action in the CNF? [message #330657] Thu, 07 August 2008 11:55 Go to next message
I extend the ProjectExplorer, and maped some file to my elements.
To open that elements, I added an actionProvider in the navigatorContent
extension.
In my actionProvider class I called the
actionBars.setGlobalActionHandler(ICommonActionConstants.OPE N, myAction);
The run() in my action just called the IDE.openEditor() method.
The strange thing is that, for some editors (infact which extends the
EditPart directly) , there can by one instance of that kind of editor,
for example, there is AEditor which is used to open the files like *.a
and BEditor which is used to open the files like *.b.
if i opened an AEditor, the if I double-click on the elements that will
open BEditor, nothing happen.
And, if I add a break-point in the run method, if I double-click, it
always will be arrive to the break-point in the run method.
That is to say, with the break-point, the run method will always be excuted.
but if I remove the break-point, the run method will not excuted(it can
be konw throug the System.out.printl("****")).
But if I right-click on the element B, and select "Open" in the context
menu, It works well.
This had made me crazy, hope that there is some one can help me.
Re: Some very very strange thing about the open action in the CNF? [message #330658 is a reply to message #330657] Thu, 07 August 2008 12:24 Go to previous messageGo to next message
Addtional,
If I opened an AEditor, then if I double-click on some B elements,
nothing will happen.
But I switch to another window, in windows xp, and switch back, and then
B elements, BEditor will open.
This message maybe help.
Dollyn 写道:
> extension.
Re: Some very very strange thing about the open action in the CNF? [message #330698 is a reply to message #330658] Sun, 10 August 2008 01:29 Go to previous messageGo to next message
Dollyn,
It's hard to determine what you problem is without seeing the code,
I had a similar problem recently and I resolved it by overriding the
handleDoubleClick method in my class which extends the CommonNavigator.
Shawn
Dollyn wrote:
> Addtional,
> Dollyn 写道:
>> extension.
>> excuted.
Re: Some very very strange thing about the open action in the CNF? [message #330704 is a reply to message #330698] Mon, 11 August 2008 04:54 Go to previous message
Well, I replaced the method IDE.openEditor(page, file); to
IDE.openEditor(page, file, false);
and everyting seams ok now.
In the JavaDoc of this method, the description about the third parameter
is: "If |activate == true| the editor will be activated. "
I'm not sure about the meanning of the "activated" here, because my
editor always "getFocus", although I give it a "false".
Shawn Spiars wrote:
> Dollyn,
> Shawn
> Dollyn wrote:
>> Addtional,
>> then double-click on some
>> Dollyn
Previous Topic:how to change editor font size
Next Topic:Open a file from outside workspace in my form editor.
Current Time: Sat Sep 06 18:13:55 EDT 2025
Powered by FUDForum. Page generated in 0.03619 seconds
