Home » Eclipse Projects » Eclipse Platform » Out of heap space when exporting plugin
Out of heap space when exporting plugin [message #330655] Thu, 07 August 2008 10:11 Go to next message
Originally posted by: pavel.orehov.gmail.com
I work with Eclipse Standard Edition 3.3.1 version on WinXP. I am trying to export, created by me plug-in with "Export Wizard" from "Overview" plug-in tab. During the build process I get an error message that Eclipse is out of heap space. I tried to increase the Eclipse heap space to 1GB (don't let me more).
My startup.ini
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
-vmargs
-Xms64m
-Xmx940m
However, it not enough, I continue to get the same error.
Yes, I have about 200 classes in my plug-in and dependencies to other plug-ins but still the memory usage is too big.
So my question is what is the alternative ways to export plugins and why Eclipse takes so much memory ? Actually, I will appreciate any help.
Pavel
Re: Out of heap space when exporting plugin [message #330664 is a reply to message #330655] Thu, 07 August 2008 13:58 Go to previous messageGo to next message
Pavel Orehov wrote:
> My startup.ini
> -showsplash
> 256m
> -vmargs
> -Xms64m
> -Xmx940m
You certainly should not need that much memory to build a plug-in of the
size you describe. By comparison, I regularly build
org.eclipse.jdt.core with much less memory than that.
Are there any errors in your error log? Are there any details of the
heap error (e.g., a stack trace)?
I notice that your eclipse.ini does not specify any particular JRE.
What JRE are you using? Are you sure? Have you tried explicitly
specifying a particular JRE to run Eclipse in, and if so, which one?
Are there any unusually large JAR files on the build path (e.g., bigger
than 20MB)?
Re: Out of heap space when exporting plugin [message #330667 is a reply to message #330655] Thu, 07 August 2008 15:15 Go to previous messageGo to next message
I am using JRE 1.5 and the plug-in project size is 16MB.
Re: Out of heap space when exporting plugin [message #330711 is a reply to message #330655] Mon, 11 August 2008 07:52 Go to previous message
Hi Pavel,
Just to mention that there is a great tool to find the reason of an Out of memory error : http://www.eclipse.org/mat/
Hope this help.
Mariot
Pavel Orehov a écrit :
> My startup.ini
> -showsplash
> 256m
> -vmargs
> -Xms64m
> -Xmx940m
> Pavel
Previous Topic:Open a file from outside workspace in my form editor.
Next Topic:[CommonNavigator] Customizing the ViewPart
Current Time: Wed Nov 05 09:05:58 EST 2025
Powered by FUDForum. Page generated in 0.03251 seconds
