Home » Eclipse Projects » Eclipse Platform » Common Navigator Framework: Link with Editor
Common Navigator Framework: Link with Editor [message #330647] Thu, 07 August 2008 04:15 Go to next message
I was trying to implement Link with Editor in my CNF viewer. I found out
that the linkHelper extension must be bound to the viewer by a
viewerContentBinding.
It seems to me that it isn't documented at all.
Please tell me if I'm wrong.
Bernát
Re: Common Navigator Framework: Link with Editor [message #330662 is a reply to message #330647] Thu, 07 August 2008 13:15 Go to previous message
You are right, this is not documented. I filed this bug so we will fix it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243466
Francis
PS - I have found it helpful to use the
org.eclipse.ui.navigator.resources plugin.xml as the example for how
things work in general (this is probably what you did)
Bernát Kalló wrote:
> viewerContentBinding. It seems to me that it isn't documented at all.
> Cheers,
> Bernát
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:inwanted shutdown.
Next Topic:is org.eclipse.core.internal.dtree.DeltaDataTree leeking memory?
Current Time: Sat Jun 14 05:07:08 EDT 2025
Powered by FUDForum. Page generated in 0.04084 seconds
