Home » Archived » M2M (model-to-model transformation) » [ATL] problem at launching ATL
[ATL] problem at launching ATL [message #2867] Wed, 27 December 2006 04:09 Go to next message
Hi ,
(1) i am performing M2M transformation(bpmn to bpel).
my sample MetaModel for bpmn is following.
filename: bpmd.ecore
BusinessProcessDiagram
Pools :Pool
Pool
Process :Process
Process
GraphicalElements : EObject
Task
taskType : TaskType
whers TaskType is XSI type Data
(2) and my model input file is following.
bpmnModel.ecore
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:bpdm="http:///bpdm.ecore">
<bpdm:BusinessProcessDiagram xmi:id="_tLfiYJVvEdusYsgvXrrVmQ">
<Pools xmi:id="_45T0YJVvEdusYsgvXrrVmQ" Id="_uqHcgJVvEdusYsgvXrrVmQ"
Documenation="New Document" Name="Pool">
<Process xmi:id="_45T0YZVvEdusYsgvXrrVmQ" Name="Process">
<GraphicalElements xsi:type="bpdm:Task"
xmi:id="_45T0Y5VvEdusYsgvXrrVmQ" Id="_wQouYJVvEdusYsgvXrrVmQ"
Pool="_45T0YJVvEdusYsgvXrrVmQ" Name="task1"/>
</Process>
<lanes xmi:id="_45T0ZpVvEdusYsgvXrrVmQ" Id="_uqHcgZVvEdusYsgvXrrVmQ"
Name="Lane" parentpool="_45T0YJVvEdusYsgvXrrVmQ"/>
</Pools>
</bpdm:BusinessProcessDiagram>
(3) my ATL file is very simple it is only print name of
BusinessProcessDiagram .
module bpmnSeq2bpelSeq; -- Module Template
create OUT : BPEL from IN : bpdm;
rule bpmnSeq2bpelSeq {
from input : bpdm!BusinessProcessDiagram
do {
input.Name -> println();
but when i run this program it generated following error .
An internal error occurred during: "Launching".
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:226)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:154)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:136)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:117)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:95)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
when i removed <GraphicalElements> entry from bpmnModel.ecore so it
works fine. but i don't why it is not wworking with <GraphicalElements>
tag.
pls help me.
thanks in advance.
Re: [ATL] problem at launching ATL [message #4435 is a reply to message #2867] Fri, 29 December 2006 03:35 Go to previous message
I suppose the problem is not in launching the transformation
programmatically, but in loading the model, which led you to refocus
your question in another post. Right?
Let us first solve the loading issue. We can come back to the launching
part later if there is also a problem there
Frédéric Jouault
brajesh wrote:
> Hi , (1) i am performing M2M transformation(bpmn to bpel).
> Pools :Pool
> Pool
> Process :Process
> Name :EString Process Name : EString
> Task
> taskType : TaskType
> bpmnModel.ecore
> </Process>
> Id="_uqHcgZVvEdusYsgvXrrVmQ" Name="Lane"
> </Pools>
> do {
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> tag.
> pls help me.
> thanks in advance.
Previous Topic:model doesn
Next Topic:Getting value from a reference
Current Time: Sun Nov 09 02:49:23 EST 2025
Powered by FUDForum. Page generated in 0.03554 seconds
