Home » Eclipse Projects » Eclipse Platform » IPartListener lifecycle question
IPartListener lifecycle question [message #330567] Sat, 02 August 2008 19:08 Go to next message
Originally posted by: no.ddress.now
Specifically, is #getViewReference guaranteed to become valid between
#partOpen and #partActivated, or is using #partActivated just better at
concealing a race condition to when #getViewReference is valid.
Here is the problem: I have a set of Views that all must track and
update based on which other members of the set are open or closed. All
Views init with
getSite().getPage().addPartListener(viewPartListener);
and check on #partOpen and #partClosed for the existing set of Views
getViewSite().getPage().getViewReferences();
On platform start-up, the correct set of ViewReferences is returned
following from the #partOpen event. Yet when views are manually
opened, #partOpen/#getViewReference returns an incorrect set: it omits
the view that is then in the process of being opened.
If I switch to using #partActivated/#getViewReference, the correct set
of ViewReferences *appears* to be returned both on platform start-up
and on manually opening Views. So, can I rely on using #partActivated/
#getViewReference to alway work corrctly?
Re: IPartListener lifecycle question [message #330683 is a reply to message #330567] Fri, 08 August 2008 08:27 Go to previous message
> Views init with
That might be a bug worth reporting.
Dani
Previous Topic:Annotatioin Presentation Layer
Next Topic:Running Ruler Action in code
Current Time: Mon Sep 01 01:56:18 EDT 2025
Powered by FUDForum. Page generated in 0.02464 seconds
