Home » Eclipse Projects » Eclipse Platform » Install of a plugin makes icons in explorer disappear
Install of a plugin makes icons in explorer disappear [message #330566] Sat, 02 August 2008 12:56 Go to next message
I have installed eclipse clearcase plugin and the I tried antlrStudio for
Eclipse. When I removed the latter one I found out that the icons in
Project Explorer has now disappeared. What a headache!
Any hints where to start looking for the info. I have tried using the
-clean flag but it does not help.
cheers,
//mike
Re: Install of a plugin makes icons in explorer disappear [message #330584 is a reply to message #330566] Mon, 04 August 2008 09:23 Go to previous message
mike wrote:
> for Eclipse. When I removed the latter one I found out that the icons in
Are you certain that you revoved all of the plugins and features that
were associated with antlrStudio? Sometimes what appears to be a single
plugin actually consists of more than one and they are not always named
consistently.
Also, try closing and re-opening whatever perspective you're using.
Hope this helps,
Eric
Previous Topic:Splashscreen and taskbar
Next Topic:running Eclipse tests
Current Time: Thu Nov 20 12:37:25 EST 2025
Powered by FUDForum. Page generated in 0.03306 seconds
