| One plugin exporting packages from jars inside itself [message #330559] |
Fri, 01 August 2008 14:59  |
I have a plugin where I put the jboss client jars that my application uses.
I then export the packages from this jars.
But today, looking at the help documentation of the Manifest / Runtime page,
I saw this:
"Since JAR'd plug-ins are the recommended format for Eclipse 3.1 and up
built plug-ins, it is recommended to leave this section blank."
Is it a bad practice to have one plugin exporting packages from jars inside
it?
If yes, somebody can tell me the best way to do this?
Thanks in advance,
Marcelo
| Re: One plugin exporting packages from jars inside itself [message #330619 is a reply to message #330607] |
Tue, 05 August 2008 16:07  |
I'm not sure if it is "bad practice" or not, but there are a couple of
things to consider:
1) The JDT compiler can't compile against nested jars, therefor you may
have issues at build time. (One of the bugs here is :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=157375)
2) The nested jars will be extracted at runtime by the OSGi framework
and place in a cache. This could potentially impact startup performance.
-Andrew
Marcelo Alcantara wrote:
> Anybody?
> Thanks.
> "Marcelo Alcantara" <marcelo.alcantara@cshg.com.br> escreveu na mensagem
> news:g6vme3$e6c$1@build.eclipse.org...
>> uses. I then export the packages from this jars.
>> page, I saw this:
>> inside it?
>> Thanks in advance,
>> Marcelo
FUDForum. Page generated in 0.03986 seconds
