Home » Eclipse Projects » Eclipse Platform » One plugin exporting packages from jars inside itself
One plugin exporting packages from jars inside itself [message #330559] Fri, 01 August 2008 14:59 Go to next message
I have a plugin where I put the jboss client jars that my application uses.
I then export the packages from this jars.
But today, looking at the help documentation of the Manifest / Runtime page,
I saw this:
"Since JAR'd plug-ins are the recommended format for Eclipse 3.1 and up
built plug-ins, it is recommended to leave this section blank."
Is it a bad practice to have one plugin exporting packages from jars inside
it?
If yes, somebody can tell me the best way to do this?
Thanks in advance,
Marcelo
Re: One plugin exporting packages from jars inside itself [message #330607 is a reply to message #330559] Tue, 05 August 2008 08:45 Go to previous messageGo to next message
Anybody?
Thanks.
"Marcelo Alcantara" <marcelo.alcantara@cshg.com.br> escreveu na mensagem
news:g6vme3$e6c$1@build.eclipse.org...
> uses. I then export the packages from this jars.
> page, I saw this:
> inside it?
> Thanks in advance,
> Marcelo
Re: One plugin exporting packages from jars inside itself [message #330619 is a reply to message #330607] Tue, 05 August 2008 16:07 Go to previous message
I'm not sure if it is "bad practice" or not, but there are a couple of
things to consider:
1) The JDT compiler can't compile against nested jars, therefor you may
have issues at build time. (One of the bugs here is :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=157375)
2) The nested jars will be extracted at runtime by the OSGi framework
and place in a cache. This could potentially impact startup performance.
-Andrew
Marcelo Alcantara wrote:
> Anybody?
> Thanks.
>> page, I saw this:
>> inside it?
>> Thanks in advance,
>> Marcelo
Previous Topic:How to get Project Path from File in Editor?
Next Topic:Text Compare - Hightlight Individual Changes
Current Time: Sun Jul 27 03:07:41 EDT 2025
Powered by FUDForum. Page generated in 0.04972 seconds
