| problems in using a custom IApplication class : AssertionFailedException [message #330558] |
Fri, 01 August 2008 14:03  |
I recently changed the Run setting for my application to use a custom
IApplication class instead of org.eclispe.ui.ide.workbench. Everything
used to work fine earlier, but now I get an AssertionFailedException
(detailed error message at end of mail)
I have checked the list plugins included and they are the same as earlier.
Infact everything remains the same except the change in the main class.
Is there something I am missing. I did see many users complaining about a
similar exception, but no solutions.
Any help would be appreciated.
Thanks in advance
-Jeevan
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
org.eclipse.core.commands.operations.AbstractOperation.hasCo ntext(AbstractOperation.java:150)
org.eclipse.ui.operations.OperationHistoryActionHandler$Hist oryListener.historyNotification(OperationHistoryActionHandle r.java:179)
org.eclipse.core.commands.operations.DefaultOperationHistory $2.run(DefaultOperationHistory.java:929)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.commands.operations.DefaultOperationHistory .notifyListeners(DefaultOperationHistory.java:918)
org.eclipse.core.commands.operations.DefaultOperationHistory .notifyAboutToExecute(DefaultOperationHistory.java:941)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:508)
com.siemens.med.cad.kmt.dkc.diagram.part.RemindNewProjectWiz ard$1.run(CustomProjectWizard.java:165)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
com.siemens.med.cad.kmt.dkc.diagram.part.RemindNewProjectWiz ard.performFinish(CustomProjectWizard.java:195)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:618)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:135)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
com.siemens.med.cad.kmt.dkc.diagram.application.RemindApplic ation.start(CustomApplication.java:41)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
| Re: problems in using a custom IApplication class : AssertionFailedException [message #330570 is a reply to message #330558] |
Sun, 03 August 2008 22:51  |
Originally posted by: lifesting.gmail.com
Hi, Jeevan. Workbench is a simple IApplication, it includes basic UI,
Workspace(resource manager), help, retarget actions, search and more....
if any of your code has referenced any function supplied by workbench
directly or indirectly, your application must be failed.
From the exception stack, it seemed that you used Redo/Undo, but the
application which replaced Workbench didn't provide complete
OperationHistory (lack Operation Context) as Workbench configured.
> a similar exception, but no solutions.
> Thanks in advance
> -Jeevan
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
FUDForum. Page generated in 0.03324 seconds
