Home » Eclipse Projects » Eclipse Platform » Following upgrade "Error: no label provider for container"
Following upgrade "Error: no label provider for container" [message #330554] Fri, 01 August 2008 09:44 Go to next message
Recently, I changed over from 3.3.x to 3.4.x based version of Eclipse,
using the same workspaces that I had previously. In the Project Explorer
view, there are a number of items that show up in the list with "Error: no
label provider for container" followed by the name of the folder/project
container.
Mylyn filtering is active.
Top Level Elements set to "Working Sets"
Folder and Package Presentation set to "Hiearchical"
Working Set is selected
Focus on Active task is enabled
Does anyone have any ideas what would cause this? Is this a bug?
Eric
Re: Following upgrade "Error: no label provider for container" [message #330557 is a reply to message #330554] Fri, 01 August 2008 11:16 Go to previous message
Almost certainly it's this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239465
> Explorer view, there are a number of items that show up in the list with
> "Error: no label provider for container" followed by the name of the
> folder/project container.
> Eric
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:Way to modify text file in RCP project before build with ANT
Next Topic:.classpath and .project reference
Current Time: Fri Nov 07 12:12:40 EST 2025
Powered by FUDForum. Page generated in 0.05259 seconds
